Best place to pickup a helmet locally
I need to get a helmet by this weekend, or else I would just order one online. Is there any place local, DFW, that has a large variety of SA approved helmets?
Thanks
Thanks
i mean most of the moto helmets are ok to use correct? as long as its DOT and SAE approved.
i used to ride all the time..if you want cheap prices on helmets if you live in plano/richardson cycle gear off 75 near 15th street is good. and if u live in dallas theres MotoLiberty off royal and 35. they both have really good prices on helmets.
or..look on craigslist. i sold mine just recently on there for 100 bucks
EvoXTX, that's not correct.
There is DOT (which is "not really" rated)
Snell M (motorcycle rated, one impact [the ground] only)
Snell SA (car, multiple impacts [roll cage], fire resistant)
Most "real" road courses want you to have an SA rated helmet. For autox or the drag strip (and some HPDEs), M or DOT is fine.
If you're going to be using it a lot, go SA. And as I learned this weekend, a little extra $$ for a lighter one is money well spent because your neck gets the pain.
See http://smf.org for the test procedure documentation.
But yes, if you're going to be tracking regularly, you're better off with an SA since tracks/sanctioning bodies may require SA and exclude M.
In DFW, I'd recommend PST. Driver's Edge usually sells some Bells at their events as well.
That's incorrect - both M and SA receive multiple impacts. SA adds an additional anvil type, fireproofing, and some other minor variations such as different eyeport requirements, etc.
From Snell (http://www.smf.org/faqs.html#7)
1. The SA standard requires flammability test while the M and K standards do not.
2. The SA and K standards allow for a narrower visual field than M standard (Some SA and K certified helmets may not be street legal).
3. The SA and K standards include a rollbar multi impact test while M standard does not.
If you can't find anything local, Simpson Race Products is in San Marcos.
http://simpsonraceproducts.com/produ...=index&cPath=1
Call your order in and see if they can ship it out today for arrival before the weekend. Or as a last resort, make the 4 hour dive.
I agree with PST, but I'll say that M rated helmets are *tested* with multiple impacts, but are not *rated* for multiple impacts (like in a car accident wheel then roll bar).
Can we agree that we're both agreeing that each other is wrong but that SA > M? (because I think that we are arguing two different points. I don't care about TESTING procedures, I care what the helmet is designed to withstand -- and I think you are talking about the testing procedures)
But yeah, I got a lot more from where that came from.
