South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Texas emissions question
Old Nov 15, 2011 | 05:49 PM
evoluXrichie's Avatar
Question Texas emissions question
I've lived in Florida all my life and never had to deal with emissions testing... but now I plan on moving to the DFW area this sumer. From what I understand there is a yearly emissions test to maintain your registration. Do they perform this check by putting a sensor at the end of your exhaust or is it just a plug into your OBD-II?
I am asking because I want to run a test pipe, but would hate to have to lift up the car every year to swap back to stock.
What is everyone in TX doing?
Thanks,
Richie
Old Nov 15, 2011 | 06:00 PM
asasin79's Avatar
obd2 scan only. they can visually inspect, but it's never happened to me.
Old Nov 15, 2011 | 06:04 PM
Thanks
Old Nov 17, 2011 | 06:15 AM
roro4g63's Avatar
Here in houstonthey do visual inspection for cat and do test with obd2 scan.
The two different places I went checked for the cat.
Old Nov 17, 2011 | 06:20 AM
4wdrifter's Avatar
if there is no sniffer test like there is in CO, but a visual check for the cat, i would just weld on the heat sheild to you test pipe. that way it looks like you have a cat and don't have to mess with it again.
Old Nov 18, 2011 | 01:01 PM
speifer's Avatar
I took my car to a Subaru dealership in Houston for inspection and they never did a visual inspection, just OBDII.
Old Nov 25, 2011 | 03:59 AM
DKC6691's Avatar
Does all of Texas require emissions tests? If not does Austin Require testing?
Old Jul 11, 2012 | 10:05 PM
okevolutionVIII's Avatar
Sorry for bringing this thread back but we don't have inspections in Oklahoma as of the mid-90s and I'm moving back to TX soon and bring the Evo with me.
I have a Magnus sheet metal IM so the whole EGR system was removed with the new build. Also tapped the cylinder head to put a 1/8NPT plug in where the exhaust runs to the intake to reduce heat and keep the IM spacer from melting. All the CEL codes for EGR and rear O2 sensor have been deleted from ever coming on with Tephra V7. Last, I have a resonated testpipe but I'm looking for a good high-flow cat to reduce certain irritating exhaust tones I dislike.
Is there anything I should make sure I do before getting an inspection as in my 11 years of driving, I've never had to do one.
Old Jul 12, 2012 | 05:40 AM
Kracka's Avatar
You'll want this: https://www.evolutionm.net/forums/ec...us-mrfred.html
Otherwise, sounds like you're good to go.
Old Jul 16, 2012 | 02:45 PM
Blue Evo 8's Avatar
Does Cobb Tuning in Plano do emissions inspections?
Old Jul 17, 2012 | 05:43 AM
Kracka's Avatar
No.
Old Jul 17, 2012 | 06:08 AM
9!'clipseDOHC's Avatar
FCOTM Winner
Hmm. In El Paso, TX they do the OBDII and the exhaust sniff test.
Old Jul 17, 2012 | 06:33 AM
Kracka's Avatar
Some counties do the sniffer, some don't.
Old Jul 25, 2012 | 02:17 PM
M00kiE's Avatar
From what I hear, Austin sniffs. I just took mine to Killeen and passed with no problems.
Old Jul 25, 2012 | 06:56 PM
Blue Evo 8's Avatar
How much is the emissions inspection fee in TX?
Here in NY is $37 and its good for one year.
I seriously plan to move to the DFW area by July 2013
