South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
aha! urika! boost enlightment
Old Mar 21, 2004 | 08:16 AM
hec-yes's Avatar
First of all I want to thank Jonas, for hooking me up with Colby(AVC-R tuner). He tuned my car and Ben's.
After Leaving the meet, I could really feel the difference in power, but I told Dan to keep his eye on the boost gauge to make sure we were not going over 1.5 on the boost gauge (1.5 kg/Cm =21.36 psi) I got in to it with a Mustang on the way to Best buy and Dan said the gauge went up to 1.6+. 1.6 = 22.76 so I called Colby and he said not worry if it spikes a little over 1.5 as long as it does not stay up there. I don't want to blow anything up so I went ahead and tested each gear vs boost pressure again and I noticed that on 4th gear it was holding at 1.6+ a little too long for my confort. So I lowered the boost level to 1.45 (it was at 1.5 with a 54% duty service) now I'm at 1.4 on the boost gauge.
AHAA! Each gear has a different boost level!!
Colby only set the boost for 2 settings - a & b not for each gear.
With my new found knowledge that each gear has a different boost, I can now customize the setting to each gear and utilize the AVC-R to it's full capabilities. Piece of cake now I am enlightened kick-*** meet last night. We had the most organized group on the srtip!
Old Mar 21, 2004 | 02:35 PM
Lowness's Avatar
Glad to hear your car is running strong hector. I told you we would get someone to help you tune your AVC-R at the meet.
Old Mar 21, 2004 | 05:53 PM
hec-yes's Avatar
thanks Andy and way to kick STI butt! I gues it's back to the drawing board for me. I tried to customize the AVC-R but did not have much luck today. I'll figure it all out and post some real numbers later.
Old Mar 21, 2004 | 06:10 PM
Mister2zx3's Avatar
I think you mean Eureka.. heh
Old Mar 21, 2004 | 07:58 PM
hec-yes's Avatar
your eeka - ureeka - yorika - iz that what u meen? yes u r korrekt. opps! type-o
