TEMEVO/SFL Info.
Originally Posted by Ev0206
Ok guys heres the deal. I just got back in the office from the walk thru of an investment property im closing on next week. I met up with my cousin since hes my mortgage broker and we went together. I left my car at his house. Apparently his son who is about 19 if im not mistaken took my car for a ride, which is fine with me but i told him not to drive hard. As im driving to the office I dont hit boost because im driving like prvrt. However when I want to pass someone I hit the gas and my boost doesnt seem to kick in the way im accustomed to. I hear it but it seems to boost then fall off a bit then I feel the boost come on again. It does not pull hard until that point. I know its not my clutch thats slipping. I doubt my tranny or transfer case have problems because theres almost always signs that let you know failure is inevitable. I took a look around and see no visible evidence of damage. The only thing I can think of is that I have a boost leak somewhere. Do you guys have any suggestions? By the way I really want to kill my cousins son. Good thing hes rich because if that boy messed anything up hes got more than enough money to pay for it.
Originally Posted by PRVRT
Does it bog down and stall when you are reaching 3500rpms???? Thats happene to me when my upper IC pipe was loose!!!! And it won't spool up!!! Check the pipes and the BOV is it the plastic one or is it MR???
Originally Posted by dr.mr
Hey Scooter, What time are you leaving your house for Homestead Sun. morning?
Do you have upgraded lower ic piping ?? if so i will check it when i put my buschur lower ic pipe that was happending since it was loose and i wasnt aware of it mad a really loud pop then boost will kick in again. i tighten it and it runs like a charm no more problems. if you have a intake check itand make sure that its around the turbo sometimes it will loosen and come off and leak and power will come and go
It does not stall and it really doesnt bog. It just doesnt go anywhere I hear it spool then boost drops and bam!!! Boost rises and I feel the kick im used to. I didnt really take the time to look at my upper IC piping carefully since I had to go back tto the office. I have the plastic bov. I figure its my bov so i might change it this weekend when I meet up with dr mr to go to the tuner shop by his house.
If you have a boost controller or boost guage check the vacuum lines.
Yeah when you check the intake look at the vac lines that run under the intake i think there's 2 lines see if they are on i believe one is vac. not sure tho but hopefully it's something small.
Yeah no problem What are your mod's ?
I have to get an aftermarket bov. I want the MR bov but if I cant resolve this problem im going to have to buy one tommorow. I know of no shop that has the mr bov in stock.
