timing belt change?
Old Mar 1, 2006 | 02:21 PM
forbidden color's Avatar
timing belt change?
any good place in AL, GA that has a place that does an excellent job changing out timing belts?
Thanks.
it's about that time...
Old Mar 1, 2006 | 02:25 PM
hel_if_ino's Avatar
I did mine, pain in the butt, but I knew that when I was done that everything was done right, torque specs. tension, no timing issues, etc. I would do yours, but I don't know (depending on where you live) if it would be worth the drive.
Old Mar 1, 2006 | 02:27 PM
hel_if_ino's Avatar
I would imagine though, now that I think about it, Top Speed in Alpharetta is an EVO heavy place, that would probably be your BEST bet.
Old Mar 1, 2006 | 06:15 PM
How did you do yours?
u should do a write up. Maybe i'll do it myself.
Old Mar 1, 2006 | 07:06 PM
hel_if_ino's Avatar
Hum, if you have time... I might be able to get one written up by friday. It was pretty tough, but I did it, and I was scared the whole time... hehe, messing with the timing is a pretty big deal, so I took my time and match marked everything! I was kind of trial and error'ing it, because I hadn't seen a write up on it yet, so if I did a write up it might not be all inclusive, but I will do my best.
Old Mar 1, 2006 | 07:23 PM
sweet.
I actually found all the diagram on how it's assembled on here. but nothing like a good write up.
I'm fairely mechanically incline and i have plenty of time before the timing belt change.
I'm looking at the tensioning tool now.
Old Mar 2, 2006 | 02:22 PM
hel_if_ino's Avatar
ehh.. stay clear of that, especially if you are doing the timing belt... you should probably replace the tensior, unless it is too expensive. I just went to the dealer and got a grenade pin from the mechanic, and used that when I took it off. I had to stick it in a vice to bring it back down some, because I couldn't get the pin in while the tensioner was installed. You are taking the timing belt off anyways, and those things have been known to snap, so just a friendly caution.
Old Mar 2, 2006 | 03:13 PM
ok, thanks.
are you still gonna do the write up"?
Old Mar 2, 2006 | 04:06 PM
hel_if_ino's Avatar
Um, yeah... like I said hopefully I will have time to do it tomorrow, I am on my way out the door right now, but I should be able to get it knocked out tomorrow.
Old Mar 27, 2006 | 08:54 PM
FastEvoFL's Avatar
Has this write up been posted anywhere?
Old Apr 3, 2006 | 06:28 PM
brokeazzlos's Avatar
if you havent done one before, i dont rec you do it
rather pay $250 than an engine
