Roll Call For Sc Evos
Old Apr 29, 2008 | 05:47 PM
  #676
8thWonder's Avatar
Sounds like the Aquamist or something? From what I saw one of those kits looked state of the art. But I'm done with meth as soon as I can get retuned.
Old Apr 30, 2008 | 06:45 AM
  #677
sabastian458's Avatar
any reason why?
Old Apr 30, 2008 | 11:28 AM
  #678
8thWonder's Avatar
Just the hassle I had with this particular kit..seals leaking, leaking at the uicp, just having to fill it up! The nearest go kart place is 30 minutes across town from me. That's a minor inconvenience considering I made 2 5 gallon jugs last almost an entire year. I never had any problems with it at all, though it could have been if I didn't catch it. I'm used to running afrs in the 10s at WOT, when it was 11.3-11.7 I knew something was up. And I actually got a chance to "feel" the failsafe David Buschur programmed into the AEM for instances like that. Needless to say, that was enough to convince me that E85 was the way to go. And a station is not 10 minutes from the house!
Old May 3, 2008 | 01:09 PM
  #679
I am having an issue with my AEM UEGO and Evoscan. The Evoscan wont record the readings from the UEGO, it wont take any readings at all. I varified that I had the right pins connected to the right wires. (pin 2= blue off gauge, pin 5= same GND as gauge)
I am at a whits end.
Old May 3, 2008 | 05:50 PM
  #680
8thWonder's Avatar
When I was running EVOSCAN I gave up on it entirely trying to wire up my UEGO to it. Good luck with it. Wish I could offer some insight to it.
Old May 5, 2008 | 05:39 PM
  #681
Mzderrick04's Avatar
Hi! My name is Robin. I'm from West Columbia. I have a 08 X GSR. Hi ya Lecon!!!
Old May 6, 2008 | 06:05 AM
  #682
SteveosEvo's Avatar
Yay, another columbia member. I'm in Irmo.
Old May 6, 2008 | 06:11 AM
  #683
tkklemann's Avatar
There is a way to run it through your ECU now, to where you don't even have to have a separate wire (USB) running into your laptop now. You can receive your wideband signals (Values) through your Tactrix cable..
Old May 6, 2008 | 06:24 AM
  #684
would you know how to do that? Or know where I can get the instructions?
I am also having a major issue with Evoscan now. I have 3 versions, v2.0, v2.1, v2.2. I started off with v2.1 and it was working great until about 3 days ago when it started not connecting to the ECU. I would just connect and give very iratic readings and the lil box that turns green for a connection would flash yellow.
so I downloaded v2.2 and it wouldnt even connect at all. It would just make attempts to connect. Then I found v2.0 and it did the same thing. So I went back to v2.1 and I can get it to connect and record most of the time. Every once and a while it will say it has timed out and to turn the car off and then back on.
Anyone ever run into that before?
Old May 6, 2008 | 12:48 PM
  #685
scottatyamaha's Avatar
When I new member comes they must take a pic of themselves by their car or else we will ban you.
Old May 6, 2008 | 10:47 PM
  #686
cangriracing's Avatar
just get mitsulogger its free and works just fine
Old May 6, 2008 | 10:50 PM
  #687
anyone in the area want to trade a full 3 inch tbe exhaust for an hks tbe exhaust. It can be ebay i dont care as long as its 3 inch. Plus in the future if you are going to sell it you will get more money out of the hks.
I can also sell the whole thing for 375 obo
Old May 7, 2008 | 07:53 AM
  #688
EvoHung's Avatar
Cool I'm in Irmo as well.
Is there a reason why you want to get rid of your HKS tbe?
Old May 7, 2008 | 11:00 AM
  #689
scorke's Avatar
3>2.75
Scorke
Old May 7, 2008 | 03:01 PM
  #690
agreed, hks is small
