Best EVO Tuner In South Florida?
Old Mar 11, 2008 | 07:21 PM
  #46
ImprezvSE's Avatar
Originally Posted by IXmr321
Just because you pay a tuner with years of experience, isnt a reason to not have a wideband. And if you have one it doesnt mean you dont trust your tuner and you're watching them like a hawk. Just an example of why you need a wideband, regardless of tuner: In the great United States of America we have this thing called weather. It is constantly changing, and can even effect the air/fuel ratio of you car.
But it's obvious you know what you're talking about. Just disregard this pointless post.
When you have a stand alone once its tuned its tuned parameters dont change just because the weather does. No MAF and no 02's my car has no adjustment, thanks for your comments.
Old Mar 11, 2008 | 08:01 PM
  #47
TTP Engineering's Avatar
The tune MOST CERTAINLY changes with the weather.
You may want to check out www.aempower.com and learn a little bit about what speed density means and how it will affect your car with barometric, humidity and temperature changes.
Old Mar 11, 2008 | 09:22 PM
  #48
04AWDTURBOEVO's Avatar
Yep, if you want a computer that will adjust to the enviroment, and correct tuning, then one must buy the all mighty Motec, .
$$$, but it is a nice system when it comes to after market ECUs'.
Last edited by 04AWDTURBOEVO; Mar 11, 2008 at 10:53 PM. Reason: better comment for topic.
Old Mar 12, 2008 | 06:18 AM
  #49
ImprezvSE's Avatar
Speed Density
Speed Density systems accept input from sensors that measure engine speed (in rpm) and load (manifold vacuum in kPa), then the computer calculates airflow requirements by referring to a much larger (in comparison to an N Alpha system) preprogrammed lookup table, a map of thousands of values that equates to the engine’s volumetric efficiency (VE) under varying conditions of throttle position and engine speed. Engine rpm is provided via a tach signal, while vacuum is transmitted via an intake manifold-mounted Manifold Air Pressure (MAP) sensor. Since air density changes with air temperature, an intake manifold-mounted sensor is also used.
Production-based Speed Density computers also utilize an oxygen (O2) sensor mounted in the exhaust tract. The computer looks at the air/fuel ratio from the O2 sensor and corrects the fuel delivery for any errors. This helps compensate for wear and tear and production variables. Other sensors on a typical Speed Density system usually include an idle-air control motor to help regulate idle speed, a throttle-position sensor that transmits the percentage of throttle opening, a coolant-temperature sensor, and a knock sensor as a final fail-safe that hears detonation so the computer can retard timing as needed.
Because a Speed Density system still has no sensors that directly measure engine airflow, all the fuel mapping points must be preprogrammed, so any significant change to the engine that alters its VE requires reprogramming the computer.
I think the last part is the point I was trying to make.
Old Mar 12, 2008 | 07:33 AM
  #50
Weather changes the VE of the motor.
Old Mar 12, 2008 | 08:16 AM
  #51
Balrok's Avatar
I don't think anybody in FL has a Motec to compare to though lol.
Old Mar 12, 2008 | 08:20 AM
  #52
06MRV8Killer's Avatar
Scott werent you just down here at USP?
Old Mar 12, 2008 | 08:25 AM
  #53
Yes for a little while.
Old Mar 12, 2008 | 11:27 AM
  #54
raymi's Avatar
Rollo at CFT is the sh*t! 30lbs of boost on the stock bottom end and the car runs like an animal. I beat the hell out of it evry weekend and have put 4k hard miles on it and the car has given me no problems. Cold weather or hot this tune is spot on, you cant argue with 20+ years of tuning exp. Good Luck finding your tuner.
Rolo is the sh&^ !!!! I have known him and his work for years and all the cars he has tuned....he is very good ! Its worth the trip to CTF if its Rolo !!! Quick question, have you heard of a guy at Japtrix in West Palm that supposely is very good with EVO's ????
Old Mar 12, 2008 | 11:34 AM
  #55
Roger @ Japtrix.
Old Mar 12, 2008 | 11:37 AM
  #56
ImprezvSE's Avatar
In case ya missed it the first time What I said still holds true, once the map is set, its set, cold, hot or otherwise. If you want any real changes you have to retune the ecu. Your the tuner here not me, I'm suprised we keep going back and fourth when this is pretty basic stuff.
Old Mar 12, 2008 | 11:50 AM
  #57
raymi's Avatar
Hi, I know there are several EVO's in Southern Florida......so we are going to do a small meet this Saturday 15th around 7pm or so in the parking lot of the Palm Beach Mall......this is in West Palm Beach on Palm Beach Lakes Blvd. 10-15 seconds off I95.....if your coming from the North you would exit on Palm Beach Lakes Blvd and turn East (left), you will see the Mall on your left side........if your coming from the South, exit Palm Beach Lakes Blvd and turn towards the East (right) and the Mall will be on your left.....if your interested pls let me know if your coming and if you have invited other EVO's so I can let the others know if its going to be cancelled or not.......hope to see you all soon !!
Old Mar 12, 2008 | 11:55 AM
  #58
sleet's Avatar
I've been tuned by Jestr and 4WS, both are very knowledgeable tuners..
Old Mar 12, 2008 | 12:09 PM
  #59
diablo2184's Avatar
TSR is out of business.
really? what happened? i need to speak to trini about a manifold
Old Mar 12, 2008 | 04:44 PM
  #60
* The fastest and quickest 6 speed Supra in the entire World is here in Orlando, Florida. Uses a Motec.
When he runs here in Florida at 90 degree weather, and goes to New Jersey and runs on 40 degree weather, the car does not need any adjustments.
* The fastest and quickest Sport Compact in the entire World is here in Orlando, Florida as well. Also runs a Motec.
You don't need to compare nothing with statistics like that.
Buy one, install it, and tune it. You may be the next fastest in the entire World too, .
