Jax FL Social Thread
Better check to see if the wall is even salvagable... take it to stage 6...or get with suprastar about the rebuild..either are good safe bets..anywhere else...at your risk.
And ya Stage 6 is usually pretty busy and most of the time they give alot of quotes with no seriousness behind it so after awhile they get that way.. have to show genuine interest. But like Freddie and I said.. have to make sure the block is still good.. a good enough cut into the cylinder wall will turn that puppy into a paperweight with a quickness....
Do you have an 8/9 or a X? What is your budget and what are you looking to spend including installation... even with a cheaper clutch you are still looking at around 1200 for parts, fluids and install...
Sounds more like might be syncros if it was clutch it would be doing it through all the gears and typically simply putting into 5th on the highway and punching it at low rpms if the rpm gauge just takes off but you go no where its the clutch.. how many miles on the trans?
hot import nights
any body down to go to hot import nights in orlando may 20th looks like there might be a good evo turn out from some other florida area threads would be sweet to get everyone out to watch some drifting and a huge car show
