HELP , Im Stuck on I85
Old Aug 3, 2008 | 04:43 PM
EvolNinja's Avatar
Originally Posted by iturregui
Could be a bad boost leak. Maybe one of the IC pipes popped. Check them
+1 I had very similar problem when I install my Injen and the UICP pop loose.
Old Aug 3, 2008 | 05:13 PM
EvolNinja's Avatar
my bad. I didn't see the other post. Hope it all worked out for you bro. Good luck
Old Aug 3, 2008 | 05:35 PM
ApacheFixer's Avatar
its all good. right now im getting a big 'ol T-bone to make me feel better. My commander chewed my *** for a little, but im ok to stay til its fixed. Dealer opens at 0730 so we will find out shortly thereafter
Old Aug 3, 2008 | 05:50 PM
wreckless969's Avatar
Hope you put in a milage pass ;-)
Old Aug 3, 2008 | 05:56 PM
chaotichoax's Avatar
moving to regional
nice to see you guys help a fellow member out
Old Aug 3, 2008 | 06:36 PM
i did. my commander bi.tched at me for having to extend another day and that if it takes until tuesday ill have to use my leave. Im pretty sure the coil pack and plugs will fix it. ::crosses fingers::
Old Aug 3, 2008 | 06:38 PM
poor car, 5 Law Enforcement Professionals kindly drove by without even taking notice.
and the vid:
Old Aug 3, 2008 | 08:55 PM
Wicked E's Avatar
The vid is a dead giveaway... You have unburnt fuel. Make sure you swap in some brand new plugs before you hit the road again. Also, see if they can allow you to swap in a used coil pack (Before you go to the parts dept. and get reamed on a brand new part that doesn't help your situation). May be a good idea to have the dealer clean your MAF right away so that's one less thing you have to do yourself (even though its cakewalk to do yourself).
-E
Old Aug 3, 2008 | 10:23 PM
depending on how much the coil pack is ill buy 2 and 4 new plugs. I have a feeling new packs and plugs will fix it
Old Aug 3, 2008 | 10:24 PM
also, i hope i didnt flood the rings with too much gas so im gonna change the oil STAT when i get home
Old Aug 4, 2008 | 05:44 AM
MORNING UPDATE: walked over to the dealer and was informed they do not stock coil packs and that they cost $277 ea. and would take until wed to get here. They also had no problem with selling me plugs for $80. Right now my plan is to get aftermarket coils from autozone/advance auto. Theyre $77ea and if they get me home ill splurge on some okada coils. The store needs to get them delivered from other stores so i should find out around mid day. If they dont work out then it looks like ill have to order the coils from the dealer.
Old Aug 4, 2008 | 06:15 AM
BlackonBlack2's Avatar
man my bad wish i was online yesterday and i read this i live off of exit 109-111 sorry bro
Old Aug 4, 2008 | 06:16 AM
FlLancer's Avatar
Good luck man..
Old Aug 4, 2008 | 07:31 AM
well, blackonblack2 came bye and let me change out coils/wires. turns out same problem. cranks up fine, afrs hang around 14-15 then after 5sec drops down to 10.0 4WS thinks it could be the front O2 so im gonna have Rick Case Mitsu take a look. wish me luck
monty
Old Aug 4, 2008 | 08:36 AM
iturregui's Avatar
Do you have any CEL?
