Steering wheel shaking
Old Mar 20, 2012 | 03:51 PM
OctaneX2's Avatar
Hey I don't know if anyone else's car does this or not. I'm wondering whether I should get it looked at or not. When I'm on the highway doing like 120 or over my steering wheel shakes like crazy to the point where my whole arm shakes. I am wondering if anyone else has experienced this or if anyone knows what I can do to get this fixed?
Old Mar 20, 2012 | 04:03 PM
Clint1291's Avatar
Get a balance and alignment that should fix it. If you're tight for money Id do balance and see how it goes. Alignment will fix more of a pull to one side. Good to get though for safety, handling and tire wear
Old Mar 20, 2012 | 04:16 PM
veegeeta's Avatar
could be a buckled wheel or out of balance or a sepo tyre dout it to be w/a unless has bad pulling to one side or exesive tyre wear best to get all checked ps forgot do you have aftermarket wheels with hub rings(hub locators) any missing?
Old Mar 20, 2012 | 05:24 PM
Vivid Racing's Avatar
Sounds like a wheel balance issue. Get the wheels balanced 1st. If that doesn't solve it, start inspecting components.
Old Mar 20, 2012 | 06:35 PM
OctaneX2's Avatar
Thanks for the responses I am going to get my tires balanced tomorow do hopefully that fixes the problem
Old Mar 20, 2012 | 06:39 PM
meckert's Avatar
so dont do 120 in a lancer--- problem solved.
Old Mar 20, 2012 | 07:24 PM
Clint1291's Avatar
120 km per hour. Like 74mph. It's not very fast. He needs to balance his tires. Hopefully should fix it
Old Mar 21, 2012 | 06:13 AM
Greedy_son's Avatar
Mine did this when i changed over my wheels. Simple fix of rebalancing.
Sometimes weights fall off etc.
Old Mar 22, 2012 | 02:14 PM
justindxin's Avatar
had the same problem when I put new aftermarket rims. wheels are shaking at 80kph.
It was hub ring problem. Before you go for balancing, check the hub rings. If there is a piece of wire that holds the hub ring inside the rim, take it out. Problem solved.
skyseer
17
Jun 29, 2025 10:02 AM
idiaroi
Jun 8, 2016 07:27 PM
Sev
17
May 15, 2015 01:01 PM
J187SD
13
Nov 19, 2011 06:04 AM
Sti69killa
Feb 17, 2011 03:45 PM
