Shift Knob
Old Apr 19, 2012 | 05:06 PM
OctaneX2's Avatar
Shift Knob
Hey jus curious as to how the lancer's shift knob comes off. Do you just twist it off?
Old Apr 19, 2012 | 05:42 PM
TRASHY_GTS's Avatar
yup, just twist it off
Old Apr 20, 2012 | 08:19 AM
link627's Avatar
I believe there is a guide on how to remove the knob on 9g, you just need to search for it.
Old Apr 20, 2012 | 05:51 PM
Duffman19's Avatar
^ you only twist it off.
Old Apr 21, 2012 | 05:56 AM
justindxin's Avatar
you cant really "twist it off". you push the plastic down, use a small flat head to pry it open.
then there is a metal clip holding it.
Old Apr 26, 2012 | 07:44 PM
stitchflip's Avatar
here you go:
http://www.youtube.com/watch?v=etJkn3c681Y
Old Apr 26, 2012 | 08:18 PM
LIVEEVIL's Avatar
So based on that video......you just yank up on it?
Old Apr 27, 2012 | 02:39 PM
OctaneX2's Avatar
Well I have a manual car
Old Apr 27, 2012 | 02:45 PM
justindxin's Avatar
push the silver plastic down, not up. use a flat head. this will expose the metal clip which holds the shift knob.
Old Apr 27, 2012 | 07:15 PM
link627's Avatar
It takes MORE than just "yank"
Old Apr 28, 2012 | 07:47 AM
justindxin's Avatar
like i said, use a flat head screwdriver for leverage.
Old May 1, 2012 | 06:48 AM
Oksamit's Avatar
On 2010 GTS Manual Trans the shaft is threaded. I had to twist the knob off much like taking the nut off the threaded rod. Do not yank anything - takes a minute to take the knob off this way. Keep an eye on the inner plastic insert as it will slide out of the knob if you let it. The inner insert is held in place with splines to the actual knob intself. Also, knob has a threaded hole behind the insert as well.
DarkSyde294
Aug 15, 2013 09:52 PM
Grimgrak
Jan 3, 2013 11:45 AM
JerseyEvox
Evo X How Tos / Installations
24
Nov 14, 2012 09:26 AM
evop99
Oct 18, 2012 11:25 AM
adWRXi
Oct 30, 2011 11:32 AM
