22psi on 91oct too high?
Old Dec 14, 2004 | 11:39 AM
titaniumkingpin's Avatar
i had my car flashed this month and my boost is sitting at 22psi dropping only 1-1.5psi by redline. is this too high for 91 pump ?
if i were to turn it down, would my tune/flash be off?
thanks for any input.
Old Dec 14, 2004 | 10:07 PM
Blitzbaster02's Avatar
get on a dyno and check your afr, or get a datalogger and check for knock. It does seem a bit high to me.
Old Dec 14, 2004 | 11:10 PM
stvbreal's Avatar
I run 22psi on 91 at high altitude. 11.5-11.2 afr. Seems safe enough. Like Blitz said get it on a dyno to fine tune it.
Old Dec 15, 2004 | 05:15 AM
TurbotrixRacing's Avatar
Hey bro ..
You might be boost spiking,,,on the road. If you pulling your car from low speeds in a high gear you will get that. Its safe where its at, if you feel more comfortable turn it down a pound, to where it was tuned
mark
turbotrix
Old Dec 17, 2004 | 10:22 AM
thanks mark, just turned it down to be on the safe side.
Old Jan 16, 2005 | 06:26 PM
sonics36's Avatar
turn it up
Old Mar 1, 2005 | 10:19 PM
Mayhew333's Avatar
Originally Posted by sonics36
turn it up
Yea, break off the knob!
Old Mar 1, 2005 | 10:27 PM
evoland's Avatar
arp head studs installed on your evo??
