P0300 code, Can you guys fix it?
Old Jan 5, 2005 | 10:13 PM
umiami80's Avatar
Well I have the 0300 code popping up every now and then, it sucks. Did you guys figure out how to flash it out? Maybe knumb the vibration sensitivity of teh Crank Angle Sensor or some type of reprogram that does not give a check engine light for this.
Anything?
Old Jan 6, 2005 | 06:42 AM
EVOTEXAS's Avatar
Yeah you can numb the CAS or the knock sensor with teflon tape around the threads. There is no electronic way to kill the code. I have it also since I put in cams.
Old Jan 6, 2005 | 07:46 AM
sir lurks alot's Avatar
will numbing the sensor get rid of the stumble also, or just the ses light.
Old Jan 6, 2005 | 07:57 AM
EVOTEXAS's Avatar
You can get rid of the stumble with tuning. Mark's flash eliminated the stumble. He removed timing at idle. The numbing of the sensors should hopefully fix the CEL. It should help prevent them from reading false knock (non-detonation vibrations). I haven't had time to do it but it works on other cars....
