TT... DYNO results
Old Nov 28, 2005 | 09:40 AM
evo0486t's Avatar
TT... DYNO results
350WHP, 325 TRQ 24PSI ON 93 PUMP...
.. just got back from TT not to long ago where I got flashed and i tell you WHAT: .. thanx to mike,paul and the rest of the guyz at TT .. u guyz definetly know your s***... nothing BUT ...U GUYZ MADE MY DAY... .!!! . and thanks to the ROTY who kept everything under control
Old Nov 28, 2005 | 10:17 AM
redman012's Avatar
Mods please
Old Nov 28, 2005 | 10:22 AM
evo0486t's Avatar
Custom TBE exhaust, custom intake, COMP CAMS 264/265, walbro 255 pump, ARP HEAD STUDS, GREEDY PROFEC B, TURBO XS BOV... everything else stock .........
Old Nov 28, 2005 | 10:35 AM
yellowEVO21's Avatar
nice numbers, what year is your car?
Old Nov 28, 2005 | 10:37 AM
evo0486t's Avatar
03..
Old Nov 28, 2005 | 11:27 AM
sleet's Avatar
24PSI, that's alot without meth or anything. Also wtf are comp cams?
Old Nov 28, 2005 | 11:31 AM
evo0486t's Avatar
some new s*** that came out... recommended from mike @ TT... all i can say is it WORKS...
Old Nov 28, 2005 | 11:34 AM
w_tomas's Avatar
Nice numbers man. I've seen the comp camps in their catalog but don't know too much about them. Obviously they make nice power. That is a very linear powerband. Congrats on the good numbers.
Old Nov 28, 2005 | 11:37 AM
evo0486t's Avatar
thanks .... ..
also thanks to the guyz from TT... they made this happened..
Old Nov 29, 2005 | 04:58 PM
TurbotrixRacing's Avatar
no problem bro happy to help...
wrick, the 280+ comp cams make about 40-50 @ the wheels (with our flash) on 05's usually.. same with 03's as long as you have the 10.5 hotside.. ive honestly not seen power gains like that with the HKS 280's.. can't beat the price of the comp cams either.. $440 a set.
-smokie
Old Nov 29, 2005 | 05:03 PM
evo0486t's Avatar
TT
Old Nov 29, 2005 | 05:17 PM
w_tomas's Avatar
-smokie
Guess we gotta throw those 280 comp cams on the list for my build in feb smokie
Old Nov 29, 2005 | 05:31 PM
evo0486t's Avatar
good luck... saw some pics of your install.. nice !! can't wait to see the numbers ...
Old Dec 2, 2005 | 11:25 AM
spoolinspyder's Avatar
Comp Cams Dyno sheet
i wanted to know why on the dyno sheet the crossover point between horsepower and torque is not at 5252 rpm like every other dyno test i have seen and run. Im not sure if your dyno sheets or dyno are reading innacurately , but i just wanted to point out the discrepency to you. Comp Cams has a few grinds available for the Evo and hopefully myself and a few other guys here in socal will be performing back to back dyno tests with the different cams & cam gear positions. Nice numbers by the way, i would just like to know why its not at 5252 RPM?
Old Dec 2, 2005 | 11:27 AM
oh ... nevamind guys i see you guys are using mph rather than RPM. Good work
