Comp cams 280???
Old Dec 30, 2005 | 03:34 PM
EVIL_EVO_VIII's Avatar
Has anyone tried these cams yet? I might just get these instead of HKS ones. 50whp!! Dayamnn
Old Dec 30, 2005 | 03:42 PM
sleet's Avatar
Originally Posted by w_tomas
Wrong, the HKS 280 exhuast cam has less lift than the 272 and 264. dafarmer is correct.
Nope, you're wrong too. It's a typo on HKS's website.
Old Dec 31, 2005 | 01:42 AM
w_tomas's Avatar
Prove the typo then...
on another note, my cousin lives in Jacksonville.. he has a red turbo hatch.. you know which one im talking about?.. have you tried to run him yet?
Old Dec 31, 2005 | 05:44 AM
Blue Evo 8's Avatar
i just spoke to Turbotrix regarding the differences between the comp cams 280's and the HKS 280's and found out that they were the same but the comp cams are a CHEAPER
alternative....
if you have the HKS 280's already hold onto them, if you are still in the market looking for cams, get the comp cams and save your self some money for other things.
Old Dec 31, 2005 | 05:57 AM
hotrod2448's Avatar
Here are the specs on the HKS cams. They are the ones not labelled in the gray on page 87. It looks like the 264 have more lift than the 272's and 280's according to crower's measurements.
http://www.crower.com/misc/m_cat.shtml
Old Jan 17, 2006 | 12:00 PM
evo0486t's Avatar
i have comp cams... All I can say is that it makes a Huge difference... i have never experienced the HKS .. But I will definetly recommend the comp cams anyday ..
Old Jan 17, 2006 | 12:23 PM
EvoTio's Avatar
This link is to Crower camshafts not to Competition camshafts.
Old Jan 17, 2006 | 12:46 PM
4TUN8's Avatar
HP per dollar is definitely there with these cams. I only got 20whp from my HKS 272s.
Old Jan 17, 2006 | 12:59 PM
Evo8Master's Avatar
I still would like to know if you need to upgrade your valve springs to run these cams??? Also how do they idle???
Old Jan 18, 2006 | 12:36 AM
evopower1021's Avatar
i have these cams in my car and they are awesome, i switched from gsc 264's to these comp cams 280's and its like a whole different car. i haven't even been tuned for the 280's yet and already notice a big difference.
Old Jan 18, 2006 | 05:13 AM
Evo8Master's Avatar
Did you upgrade your valve train? Did you loose any low end torque? How is your idle?
Old Jan 18, 2006 | 09:19 AM
TT said these can be used with stock valve train
Old Jan 18, 2006 | 09:44 AM
kike_4g63IV's Avatar
Well,I guess that if you keep the stock rev limiter then you can use the stock valvetrain.
Old Jan 18, 2006 | 10:32 AM
hotrod2448's Avatar
I know, I was showing the specs on the HKS units. They are the ones in gray. People were discussing if all the HKS cams have the same lift or not.
Old Jan 18, 2006 | 01:42 PM
TurbotrixRacing's Avatar
Stock valvetrain will be fine even with the Rev limiter raised to 8k RPM. The stock valvetrain will handle a lot more than people think.
Keith
