Need to know how to hook up boost controller to 50 trim
Old Jun 19, 2006 | 06:07 PM
BoostWhore's Avatar
If anyone could help me i need to know how to route my manual boost controller to the tial wg there are two nipples on the wg itself. There were no diagrams with the kit
Old Jun 19, 2006 | 06:43 PM
F.O.G.'s Avatar
I'm sure someone, maybe even TT will answer you. I have the TT 50 trim that was installed by them. Problem is my car is not at my house cuz we are building a RSX motor right now and the RSX is in the EVO stall. So I guess I'm just writing to let you know that I'll check back tomorrow and if nobody answered you yet, I'll go check my car and get back to you.
Old Jun 19, 2006 | 10:20 PM
BoostWhore's Avatar
thanks
Old Jun 20, 2006 | 07:12 AM
BoostWhore's Avatar
up
Old Jun 20, 2006 | 08:21 AM
F.O.G.'s Avatar
OK bro...here we go. From the side outlet of the wastegate to the side of the MBC.
From the bottom of the MBC to the top of the BOV. That is how TT hooked mine up. I have a Tail wastegate, tail BOV and Hallman MBC. I hope this helps. Good luck
Old Jun 20, 2006 | 06:21 PM
BoostWhore's Avatar
so is it td off of the blow off valve line for the input into the boost controller
Old Jun 20, 2006 | 06:36 PM
DEL TURBO's Avatar
You should have a fitting on the compressor housing. I had mine t'd off the bov line, but switched to the compressor. Mine went from turbo (compressor nipple) to bottom of Hallman mbc, then side of mbc to side of Tial wastegate. I've read that when you t off the bov, you get both pushing and pulling on the wg diaphram.
Old Jun 21, 2006 | 05:14 PM
BoostWhore's Avatar
up for more anwsers. The turbo doesnt have a outlet like the stock one does im not sure if your rnr kit did
Old Jun 21, 2006 | 06:16 PM
Spaceball 1's Avatar
F.O.G. is correct. He is a little unclear about the Input of the MBC ( the bottom port) is can go to any boost source, UICP, LICP, intake mani, or compressor housing if avai. The BOV line can be T'd and ran to the MBC, like F.O.G. said just alittle unclear.
Old Jun 21, 2006 | 08:22 PM
BoostWhore's Avatar
so u need to send a boost source to the side of the wastegate as well
Old Jun 22, 2006 | 08:36 AM
F.O.G.'s Avatar
I saw that you still had some questions so I went and checked my car again. I don't think this will help you because I have a Magnus intake. But I'll run it by you anyway and I'll try to be more specific.
The line runs from the wastegate to the side outlet of my Hallman MBC. From the bottom outlet of the hallman around back of the engine to a nipple on the MAGNUS intake. There is a TEE in that line which runs to the BOV. That is how TT set mine up. If this is no help, I suggest calling TT and I'm sure they can direct you.
Good luck
Old Jun 22, 2006 | 09:04 AM
That is PERFECT
Old Jun 22, 2006 | 05:19 PM
F.O.G.'s Avatar
We got it this time ??
Old Jun 22, 2006 | 10:55 PM
BoostWhore's Avatar
finally got it hooked up right on the dyno... you only use the lower port on the wastegate on a mbc. I need an electronic the hallman doesnt seem to be real steady on the external wastegate
Old Jun 23, 2006 | 06:02 AM
Anarchy99's Avatar
I have a Blits SBC-IDIII for you if you need one. PM sent
black E
11
Oct 21, 2014 04:34 PM
black_beauty
Jul 16, 2014 05:57 AM
802EVO
Jun 11, 2014 03:10 PM
dolphin888
Apr 24, 2011 10:15 AM
