Evo Ix Tt Tuned 6/26/06
Old Jun 26, 2006 | 02:36 PM
dsmjeffro's Avatar
WELL JUST GOT HOME FROM TURBO TRIX IN EDISON NJ PRETTY ****TY DAY TO GET A CAR TUNED NOTHNG BUT RAIN AND HUMIDITY
OTHER THEN THAT EVERYTHING WENT PRETTY WELL
CAR HAD A BASE PULL OF 244.75 HP & 259.34 TQ
ONLY TOOK THEM A COUPLE PULLS TO GET THE CAR RIGHT
I DIDNT SEE ANYTHING BUT I COULD ACCUALLY HEAR THE CAR MAKING MORE HP SITITNG ON THE COUCH......................
MY CAR ENDED UP MAKING 350.51 HP & 350.89 TQ LITTLE BETTER THEN I EXCPECTED LOOKING AT EVERYONE ELSES #S
MY MODS ARE
AMS UPPER & LOWER IC PIPING
HKS 280 EXHAUST CAM
WALBORO 255 PUMP
HALMAN BOOST CONTROLLER
K&N CONE FILTER
ARP HEAD STUDS
FULL 3`` EBAY EXHAUST FOR $245.00 WHICH I AM VERY PROUD OF
THANKS MARK ESP FOR TUNNING MY CAR
& THANKS FOR BEING ONLY AN HOUR AWAY IF I EVER NEED ANYTHING BE SURE TO CALL YOU GUYS FIRST
& AS FAR AS EVERYONE ELSE I DEF RECOMMEND YOU TO THESE GUYS
Old Jun 26, 2006 | 07:11 PM
mrdevo's Avatar
Pretty good numbers....I had the white one and was getting the alchy tuned. Nice meeting you and def. drive that beast more often lol
Old Jun 26, 2006 | 07:14 PM
Peteypab2133's Avatar
is it wise to change the cams in the IX already? thought they were not produced yet, and you could only truely change one cam.. Is it worth buying a set of them or can you buy them seperate like that?
Old Jun 26, 2006 | 07:20 PM
SlowCar's Avatar
what kind of gas and what psi(base/tuned)?
Old Jun 26, 2006 | 07:23 PM
RenoEvo's Avatar
People are hitting those numbrers w/o the cam, but every car is different
Old Jun 26, 2006 | 07:28 PM
Jussb1aze's Avatar
True, I'm at 328/309 with my mods....I'm hoping to get above 350 with an intake, downpipe w/cat-delete and a custom tune.
Old Jun 26, 2006 | 07:33 PM
34Turbo's Avatar
I got 344 and 329 w/o the exhaust cam. I am waiting for the cams to come down a bit and possibly a 50trim...
Old Jun 26, 2006 | 08:41 PM
cij911's Avatar
MY MODS ARE
HKS 280 EXHAUST CAM
WALBORO 255 PUMP
K&N CONE FILTER
ARP HEAD STUDS
Wow! Very nice...100+ Hp gain from your mod's is quite respectable....Congrats & enjoy...
Old Jun 27, 2006 | 05:10 AM
dsmjeffro's Avatar
that is on 22 psi pump gas my car holds pretty well though only drops off to 21 psi
car was set @ 22 psi when i brought it in
when i look at all the numbers put down with cars with out the cam hp is only a little higher
i do have alot more tq though wich is a big plus
i will post my dyno sheet if they send it to me
Old Jun 27, 2006 | 05:58 AM
2StepsAhead's Avatar
Damn, the more I see these threads, the more I know I need to get tuned...my car feels like a dog with just the turbo back and mbc, hopefully the tune will create a little less boost taper for me also.
Old Jun 27, 2006 | 05:59 AM
Jussb1aze's Avatar
Nice taper, mine usually tapers about 3-4 psi. Is theirs a dynojet? If so you could have them email you the results, then go to dynojets website and download the program to view it. It's pretty nice.
Old Jun 27, 2006 | 06:45 AM
dsmjeffro's Avatar
yea it is a dyno jet and i will have to do that
i think the intercooler pipes took away all the taper with the stock icp`s i had like 4 psi taper would hit 22 drop off to 18 or 19 as soon as i installed the ic pipes it held strong
Old Jun 27, 2006 | 07:49 AM
Jussb1aze's Avatar
how much did the pipes run?
Old Jun 27, 2006 | 08:00 AM
Kc2Buk's Avatar
MY MODS ARE
HKS 280 EXHAUST CAM
WALBORO 255 PUMP
K&N CONE FILTER
ARP HEAD STUDS
NICE GAIN!!!
Its good to start with a baseline dyno to see how much gain you really scored.
350 whp is a great place to be.
Good luck, Drive safe,
Old Jun 27, 2006 | 08:04 AM
saiyanzzrage's Avatar
true, im putting 342/362 to the ground without cams...i cant wait to see what cams do to my ix
