ix with cams tuned
Old Jun 28, 2006 | 06:25 AM
eve-slow's Avatar
Jeffro, please turn off CAPS LOCK. Thanks, bud.
Jon, what's special about the TT 280 intake cam, is that this is a IX, and that's the only intake cam in existence (for now) that works on a IX.
Arn't GSC's cams available yet?
I also agree with you on the boost leak issue, stock IX valves shouldn't leak at 22psi.
Old Jun 28, 2006 | 08:53 AM
vwjeff's Avatar
It's kind of hard to hit 355wtq with a slipping clutch, since the clutch will slip the most right at peak torque. Unless it was completely slipping, then it wouldn't affect the peak WHP at all, since that occurs up near 6500-6800rpm well after the clutch has begun to grab fully (due to less torque at higher rpm).
A boost leak would not be surprising with the LICP - that's pretty common - but the BOV? I highly doubt the stock BOV is leaking on pump gas boost. I have pressure tested several IXs stock or near-stock IXs that didn't have any leaks up to 25psi. Just be sure to do a pressure test before you go back, but the clutch you can't do anything about until you replace it. It's probably time to do that, since you're going to be driving around in a very powerful IX.
I don't see that LICP leaking boost seems how it comes with T-Bolt clamps
Old Jun 28, 2006 | 09:24 AM
j3ffw19's Avatar
iam sure that the licp is leaking,yeah it has tbolt clamps but if its installed wrong it will leak. thats why iam going back up there on the 10th to sort out the problems.
btw turbotrixs did not instal the pipe I did.
Old Jun 28, 2006 | 09:26 AM
j3ffw19's Avatar
I give turbotrixs credit they turned my evo into a beast, just like everything you do there could be problems. but the tune is badass no doubt about that
Old Jun 28, 2006 | 11:13 AM
Warrtalon's Avatar
Yeah, vwjeff, why would you say that? You could have it sealed in concrete and still have a leak if it wasn't done properly. T-bolt clamps are only as good as the person who installs them, and the most common boost leak on the Evo is after an LICP install. All it takes is a simple pressure test to verify. The good thing about the t-bolt clamp is that if he does find a leak down there, the t-bolt clamp is his best bet to get rid of it...
Eve-slow, no not yet, but last time I talked to Greg, they had 75 pre-orders. It's probably over 100 by now.
Old Jun 28, 2006 | 11:26 AM
vwjeff's Avatar
As long as the pipe is straight in the couplers he should be ok. But there always that what if?
Just woundering if that is way mine only makes 19psi WOT? Might check mine now (you always got me thinking)
Old Jun 28, 2006 | 12:00 PM
saiyanzzrage's Avatar
Originally Posted by j3ffw19
i would'nt say awesome but decent numbers, some ix are doing this with out the cam so more tunning needs to be done. and hopefully the boost leak when fixed will help produce better numbers.
are those numbers on a mustang or a dynojet? (for some reason my work firewall is blocking the link to your sheet) im putting down 342/362 on pruven's dynojet with basically the same mods, but no cams on my ix...i added a ceramic coated ebay o2 and stock ported/coated after the tune, so the car has prob a bit more in the hp/tq department now
Old Jun 28, 2006 | 12:12 PM
Rnm's Avatar
Rnm
^Its a dynojet as well.
Old Jun 28, 2006 | 01:08 PM
j3ffw19's Avatar
i think after the boost leak is taken care of and turn up the boost alittle more it should produce some good numbers.
Old Jun 29, 2006 | 01:33 PM
RoughedgesMR's Avatar
wow, i am doing the cams next week and really hope i put down way better numbers. Not to hate on you though. its just that i put down 342whp and 331 tq on the same mods minus the cams and licp.
Old Jun 29, 2006 | 01:50 PM
evoate ya's Avatar
All cars dont respond the same to mod's and not all are created equal. Some make more power, some might make alittle less. Their are alot of variables that play in to the outcome, like boost leaks, outside air temp, etc. when it come to making good power. As long as the car performs well on the street and at the track I would be happy. Just my .02
Old Jun 29, 2006 | 01:51 PM
Rnm's Avatar
Rnm
x2
Old Jun 29, 2006 | 03:19 PM
j3ffw19's Avatar
if iam not mistaken your car is tuned at 24psi, mine is set at 22psi with a boost leak so who knows how much i have lost. like i said with tuning and the boost leak fixed it should put down some good numbers.paitence is key
Old Jun 29, 2006 | 03:36 PM
2003lancerevo8's Avatar
FYI: GSC does have cams out, AMS is tunning a evo right now with them.
Thanks
Old Jun 29, 2006 | 03:45 PM
Warrtalon's Avatar
Yes, but they are testing the first set, so they're not available to the public.
