Evo IX w/ alky
Old Jan 23, 2007 | 08:53 AM
statix's Avatar
29.5psi+Meth = conservative???
Old Jan 23, 2007 | 09:13 AM
EVIL_EVO_VIII's Avatar
Hes reffering to the A/F ratio. Still on the rich side.. With meth you can run 11.9-12.0 A/f ratios meaning more power!
Old Jan 23, 2007 | 09:21 AM
SlowCar's Avatar
Old Jan 23, 2007 | 09:00 PM
34Turbo's Avatar
Originally Posted by EVO8URV8
u got any fail-safes with the kit?
Yep. If the system senses any kind of irregularity in the pump pressure (including pump failure) it automatically dumps to wastegate pressure. As a matter of fact on the first pull I had the ground wire to the pump not connected and the car wouldn't boost above 12psi...
Thanks. Yeah, he could have leaned out the AFR a lot more. As a matter of fact I'm shooting huge flames out the back if I go WOT on 5th and just let go. My VTA set up probably has something to do with it as well. As soon as I let go I see 9.1 on my wideband.
Old Jan 23, 2007 | 09:37 PM
SlowCar's Avatar
https://www.evolutionm.net/forums/sh...7&postcount=12
its the injection kit. when you let off, the "massive" pump rotor is still spinning, injecting methanol when its not suppose to. A solenoid valve before the alky injector will remedy that
Old Jan 24, 2007 | 07:29 PM
Hot Wheelz's Avatar
My ix is Awesome to Drive!! - Meth is the way to go!!! Check out My Sig. The guys at TT can Tune
Old Jan 24, 2007 | 10:47 PM
34Turbo's Avatar
Didn't know that. Thanks bro. Good stuff
Old Jan 24, 2007 | 11:56 PM
version 2 beta's Avatar
Is that a spike to 29.5 psi at approx 3500-3700 rpm and then tapers to?
It seems to be a very short power band from what the posted graphs show because from 3800 rpm through 4400 rpm he hit peak HP but then falls dramatically and by 7000 rpm he is barely puffing over 260 HP.
The torque comes on pretty late and the cross over doesnt happen until 5400-5500 rpm and peaks at 6000 rpm and starts to drop.
If i'm reading right the shift point is at 7600-7700 rpm... Great numbers... but that's it. This power band blows
Old Jan 25, 2007 | 08:09 AM
mrdevo's Avatar
I'm not sure what you are looking at but the graph reads totally different.Hp holds 375 to redline then falls off at a good rate. The torque is over 250 at redline too. Are you looking at something different?
Old Jan 25, 2007 | 09:01 AM
High_PSI's Avatar
This would be a fast car, I made 347/342 on that Dyno and Trapped at 113MPH on 93 3500 pound car with my butt in it. this should be near or past 118MPH.
Old Jan 26, 2007 | 08:13 PM
34Turbo's Avatar
Yeah, I think that you are reading it wrong. Peak hp is at 6K and barely drops off. Optimal shift point would be around 6.5K.
Old Jan 29, 2007 | 07:34 PM
Evo4u2envY's Avatar
Peak torque is at 3900-4000 rpm in this car...both the power, and the torque will fall off rounding redline because the stock turbo will NEVER hold 29.5 psi... the powerband on this car is FAR from ****ty...fix your specs and scrutinize the graph a little further
Old Feb 2, 2007 | 10:36 AM
FastAzzEvo's Avatar
can't u just run race gas if you were at the track and raise the boost instead of getting a meth kit?
Old Feb 2, 2007 | 02:37 PM
dafunk630's Avatar
thats is why i love meth!!!
Old Feb 2, 2007 | 02:49 PM
Ultimate CC's Avatar
Got to love the meth...
