Slowboy Racing will not be undersold!
Old Aug 5, 2009 | 07:42 AM
  #31
SBR INC's Avatar
AEM Water/Meth Injection Kits
AEM week is going strong! I'd like to take a second to show you more about AEM's Water/Meth kit. This kit is one of my personal favorites. I've installed many of them and feel that it's one of the best buys and performers on the market. It's simple design makes it very user friendly, easier to install than most and very reliable. The system can be integrated to just about any setup and can help you really get the most out of your setup. We have two options and the difference is in the tank. Check it out!
AEM Water/Meth kit w/ 1 Gallon Tank
STANDARD WATER INJECTION KIT
  • Universal kit includes everything you need for installation
  • Progressive, controller-driven 150 PSI pump
  • One-gallon tank with integral fluid level sensor
  • Dash light for system status and low fluid warning
  • Alcohol Compatible (up to 50% in solution with water)
  • Progressive controller, provides boost-dependent
    variable flow
  • Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
  • Includes three jets to match your power requirement
We also have their HD kit which comes complete with a 5 Gallon tank for those with a greater addiction to speed and boost.
HD Injection Kit
HD WATER INJECTION KIT
  • Kit includes everything needed for installation
  • Large-capacity 5-gallon reservoir with integral fluid level sensor
  • Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
  • Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
  • Dash light relays system status and low fluid warning
  • Methanol & alcohol compatible (up to 50% in solution with water)
  • Includes three jets to match your power requirements
  • Reduces exhaust gas temperatures (EGTs) and inlet air temps on turbo-diesel and gas applications
This is just another great product from AEM. Contact one of our sales reps today to help you pick the right kit for you! Check out the rest of the great products from AEM on our site at www.slowboystore.com
Remember folks, we won't be undersold! Let us know how we can EARN your business!
Marti
GM @ Slowboy Racing
Old Aug 6, 2009 | 07:21 AM
  #32
SBR Inc2's Avatar
Well, Discovery channel has shark week and we're still running AEM week!
As part 4 of our week long series of AEM awesomeness, I give you AEM's Digital Display Gauges!
These gauges offer precise metering sensors with a very compact and visible display. These gauges are the perfect alternative to other gauges that cost an arm and a leg. Performance building require accurate readings and these are the tools for the job!
All of the vitals are represented!
  • Voltmeter Gauge (8-18V)
  • Oil/Fuel Pressure Gauge (0-100psi)
  • Oil/Transmission/Water Temperature Gauge (100-300F)
  • Boost Gauge (-30-35psi)
  • Boost Gauge (-30-50psi)
  • Oil Pressure Gauge (0-150psi)
  • UEGO Controller "Display"
Bundle them up and we can work out a great savings package! Check and these and thousands of other great products at Slowboy Racing Inc. - The performance experts for factory turbocharged vehicles. - Homepage! Thank you for your time and continued support.
Old Aug 7, 2009 | 07:40 AM
  #33
SBR Inc2's Avatar
It's day 5 and the final day of AEM week!
The AEM EMS is one of the most commonly used management systems in the world. They offer support like no other and the system has a wide variety of features. These systems come in plug and play varieties for most of the popular tuning platforms.
AEM EMS
AEM’s Plug & Play Engine Management System (EMS) plugs directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. An integrated tuning wizard allows users to create a base map specifically for a car’s configuration, regardless of what type of injectors, sensors, coils or other changes have been made. The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
* Installs in minutes using Plug & Play technology—no wiring necessary!
* Start-up calibrations included
* Live help window eases tuning process
* Set-up Wizard creates a custom base map for your car
* System is fully enabled—Never pay for upgrades!
* Free software updates on aempower.com
* Uses all the factory sensors
* Runs on Windows™ compatible software
* Fuel table automapping
* Programmable traction control
* Onboard 512kb datalogger
* Up to 10 cylinder sequential fuel injection
* 16 general-purpose outputs
* 7 definable switch inputs
* Electronic boost control
* Soft cut rev limiters
* Two step launch control
* Wet or dry nitrous control
* Definable knock control
* Full idle control
* 4 EGT inputs with fuel control
* 16/32 hybrid high speed processor
We have some great bundle deals that include temp/map and other sensors to make the kit as simple to use as possible. Contact one of our reps today about getting setup the right way.
Check out this and all of the other awesome AEM products we've got on Slowboy Racing Inc. - The performance experts for factory turbocharged vehicles. - Homepage!
Old Aug 10, 2009 | 07:12 AM
  #34
SBR Inc2's Avatar
Happy Monday, everyone! It's a new day, a new week and a new product line of the week! This week it's all about ACT! We'll post an update with a new product every day!
Today we're going to feature the ACT HD Clutch Kit!
The ACT HD is one of the best options on a street car with bolt ons. This clutch typically features a full face street disc with ACT's 2100lbs pressure plate. We highly recommend this clutch for anyone making more power than stock or track weekend trips!
The kits come complete with an alignment tool and throw out bearing.
Check out this and over 50,000 other products on our site, www.slowboystore.com!
Old Aug 10, 2009 | 07:20 AM
  #35
SBR Inc2's Avatar
yeah baby! You read it right! We've got the Exedy Twin Disc Clutch Kits ready to ship with free next day! These really shouldn't need any introduction but here is the pitch!
The twin disc clutch kit offers superior performance when you are making real power! The twin disc design allows you to better handle added torque on both street and track. The kit comes complete with plate, discs and flywheel!
We've got a great deal on these today with next day shipping included!!!!
Contact one of our reps today to get you the right kit for your car!
As always, check out all of the great products we have available for you on www.slowboystore.com![/
Old Aug 11, 2009 | 08:21 AM
  #36
SBR Inc2's Avatar
it's day 2 of ACT week and today we are highlighting the ACT XT Clutch kit!
These kits are one of the standards in the tuning world. These clutches are built to handle serious torque and power. If you're running an upgraded turbo, an aftermarket turbo system or hit the track, you need to have a clutch that will hold the gains! This kit is available with a sprung street disc or sprung or unsprung 6 and 4 pucks.
You can see this and over 50,000 other quality products on our site at www.slowboystore.com!
Old Aug 12, 2009 | 07:16 AM
  #37
SBR Inc2's Avatar
And the saga continues.... Today we're featuring ACT's XX Clutch kit.
This kit is more commonly known as the 2900 and has been used for years to handle serious power! Before there were tons of twin disc options, people used these clutches with all kinds of different discs to handle power and boy did they work! This kit is obviously not for everyone. You will see a real increase in pedal pressure and a stronger engagement than most other clutches.
This kit is available with a solid street disc and both sprung/unsprung 6 or 4 puck styles. If you're racing or just tired of burning up clutches, this is one bad mamma jamma! Check out any of the over 50,000 products on our site Slowboy Racing Inc. - The performance experts for factory turbocharged vehicles. - Homepage
Old Aug 12, 2009 | 07:24 AM
  #38
tweakdsm's Avatar
I did order few things from SB, parts always on time, would recommend.
Old Aug 12, 2009 | 07:41 AM
  #39
cheb evo's Avatar
What's the status of the Goodridge brake lines? Was going to really soon. Thanks!
Old Aug 12, 2009 | 09:16 AM
  #40
SBR INC's Avatar
got them on the shelf, my good man! give us a call or shoot me a pm with your contact info and we'll get you an estimate. We've also got some KILLER deals on DBA rotors with hawk pads if you'd like to upgrade everything at once. Let us know how we can earn your business.
Marti
Old Aug 12, 2009 | 09:19 AM
  #41
SBR INC's Avatar
thanks buddy. let us know if we can be of any help in the future.
Old Aug 13, 2009 | 07:20 AM
  #42
SBR Inc2's Avatar
It's day 4 of ACT week and it's time to highlight the ACT Pro-Lite flywheel!
ACT XACT ProLite Flywheels provide significantly improved engine response, acceleration and a higher degree of safety than the heavy stock flywheel. Many competitor flywheels are too light, fragile and expensive. ACT offers exactly what performance enthusiasts.
All XACT ProLite Flywheels are true one-piece designs CNC machined from forged Chrome-moly which is stronger and more durable than billet steel or aluminum.
You can find this and over 50,000 other great products on our site, Slowboy Racing Inc. - The performance experts for factory turbocharged vehicles. - Homepage
Old Aug 18, 2009 | 04:02 PM
  #43
SBR Inc2's Avatar
We've been hard at work adding only the best manufacturers in the biz to our line up! Here are just a few examples of the companies that we have to offer!
ACT
ACT is one of the staples of the industry. They offer a clutch for just about every application with all kinds of performance ranges. With their lines including their HD, XT, XX and more, we have the ACT clutch that will be right for you!
Exedy
Exedy offers one of the largest assortment of clutch and flywheel kits on the market! As the OE for many of the standard and performance brands on the market, you can be assured that Exedy quality is second to none. We products ranging from their Stage 1 replacement kits to their Carbon Triple Disc Kits!
Fidanza
Fidanza has been one of the biggest names in the business for a very long time! Their flywheels really put them on the map and now they offer clutch kits, shifters, axles and more! Check out our site for their complete product offerings for your project!
Clutch Masters
Clutch Masters offers a complete line of clutches and flywheels to meet just about any demand. Their clutch kits come in basic replacement models and go as far as multi-disc models for the race builds!
Competition Clutch
Competition Clutch offers a great product at a great price! They have yet to really be as MAIN STREAM as some of the other brands but it's a line that we are very familiar with and have personally used for Drag Racing, Drifting and all kinds of street use. They have great street kits and even some excellent options for Multi-Plate kits!
These are just some of the options that we have available! Needless to say, there is not drivetrain need that we can't meet for you! We have all of the quality brands and remember..... WE WILL NOT BE UNDERSOLD! We will do our best to match or BEAT any price!
thanks for your time, we look forward to working with you!
Old Aug 19, 2009 | 09:27 PM
  #44
evovin's Avatar
Do you still carry Magnus Fuel rails black anodized (methanol compatible)?
It used to be in your site for $140 but its not there anymore?
Old Aug 19, 2009 | 10:33 PM
  #45
Levar's Avatar
Veteran: Army
Wow! Now this is a bold statement and certainly should grab the attention of all EVO owners. I'm on my way to the SBR website for some searching. I need some FIC 1200cc injectors to run with my E85 set up.
