BBK-B- ready to go ;)
Old Oct 20, 2010 | 06:33 AM
  #31
CBRD's Avatar
Originally Posted by Go_Lancer_Go
Wow, cannot believe the day has arrived!
Few questions...
I'm aiming for 450whp, is 950cc injectors enough? Ported Exhaust manifold good enough? Do I need a double pumper? I'm also getting S2's. This should do the trick?
950's should do the trick, i mostly run pte1000's on single pumper walbro
cb
Old Oct 20, 2010 | 06:40 AM
  #32
Go_Lancer_Go's Avatar
Awesome!!!
So pumped now!
Old Oct 20, 2010 | 02:08 PM
  #33
nonschlont's Avatar
just got off the phone w/ Chad... Just purchased a BBK-B Woot Woot!
Pics, and results when I have them...
Old Oct 20, 2010 | 02:31 PM
  #34
CBRD's Avatar
BOOYA!
thank you sir!
email confirmation being sent now!
cb
Old Oct 20, 2010 | 03:49 PM
  #35
4G63K's Avatar
How is this turbo on the top end? Does it pull all the way to Redline?
Old Oct 20, 2010 | 04:08 PM
  #36
MJ23FE's Avatar
Search, noob!!! :P
-Jalal
Old Oct 20, 2010 | 04:19 PM
  #37
MJ23FE's Avatar
Double post. I'm a noob!
Old Oct 20, 2010 | 04:28 PM
  #38
L888Apex's Avatar
can't wait for you to post some results on here or on sce or both LOL
Old Oct 20, 2010 | 07:18 PM
  #39
4G63K's Avatar
Bump
Old Oct 20, 2010 | 08:24 PM
  #40
MJ23FE's Avatar
Bump
What are you looking for?
https://www.evolutionm.net/forums/ev...b-results.html
https://www.evolutionm.net/forums/ev...5wtq-93-a.html
https://www.evolutionm.net/forums/ev...brd-bbk-b.html
-Jalal
Old Oct 21, 2010 | 10:03 AM
  #41
CBRD's Avatar
4 more orders processed today!!
thanks everyone for your support!
cb
Old Oct 21, 2010 | 10:10 AM
  #42
detroit pistins's Avatar
Originally Posted by CBRD
going out tomorrow
cb
so are those the mystery boxes ur selling for $15?
http://www.cbrdspeedfactory.com/CBRD...stery-Box.aspx
Old Oct 21, 2010 | 10:22 AM
  #43
Spec-Ops1's Avatar
We should have some orders coming your way as well... waiting on customer replies
Old Oct 21, 2010 | 11:50 AM
  #44
4G63K's Avatar
I think this is what i was looking for.
there is about a 250 rpm difference in initial response, but the transient is slightly different,
the bbk full is awesome as far as spool... the BBKB will be able to run sustained high boost pressures with the bearing upgrade..
just for reference, i went from 25.8 psi tapering to 24.5, then ran 26 psi peak and flat 26 to redline, the car picked up 21whp.... not bad for 1.5 more psi
cb
Old Oct 23, 2010 | 09:40 AM
  #45
curtisb's Avatar
wat does this turbo set up have over the fp red?
