Products at Boomba Racing Inc.
Old Mar 2, 2011 | 05:41 AM
Boomba Racing's Avatar
Boomba Racing is proud to present our new line up of Maley and ACL products for the 4B11T!
We now have in stock:
Manley platinum series light weight pistons!
Manley pro series turbo tuff I beam steel connecting rods!
ACL performance main bearings!
ACL performance connecting rod bearings!
Get your motor going with these amazing high quality products.
Email sales@boombaracing.com for pricing info!
~Dan~
Attached Thumbnails Products at Boomba Racing Inc.-103_0908.jpg   Products at Boomba Racing Inc.-103_0912.jpg   Products at Boomba Racing Inc.-103_0913.jpg
Old Mar 2, 2011 | 09:22 AM
Evo X/Ralliart Fuel Rails @ Boomba Racing Inc.
We have our Evo X/Ralliart fuel rails in stock right now ready to ship!
Boomba Racing EVO X Ultra High Volume Fuel Rail is machined from solid aircraft quality aluminum billet. This rail has AN-8 fittings on both ends which can increase fuel flow by 50% compared to stock. The fuel rail has large 17.5 mm internal bore that can easy support 1000hp. It has 1/8 NPT gage port and adaptor port for stock fuel pressure regulator. FPR port blocking adaptor is supplied with each rail in case aftermarket FPR is used. Rail comes with preformed stainless steel supply pipe that mounts directly to factory fuel line. It is designed with true expansion in mind. It can be used as a bolt on with all factory fuel lines and injectors or as a part of sophisticated aftermarket fuel delivery system. Available in natural aluminum, red, blue and black anodized finishes.
Prices on the website:
http://www.boombaracing.com/evo10.html
Email if you have any questions! sales@boombaracing.com
~Dan~
Old Mar 2, 2011 | 09:23 AM
Evo X Motor mounts @ Boomba Racing Inc.
We now have our Evo X/Ralliart Motor mounts in stock and ready to ship!
Boomba Motor Mounts are designed to gain better traction, improve acceleration and help wth smoother gear shifts. Boomba Motor Mounts kit replaces both front and rear engine torque damper. Mounts are machined of lightweight, aircraft quality aluminum with solid, molded polyurethane bushings. The polyurethane hardness is carefully chosen so the engine mounts do not transfer any excessive vibrations to the body but significantly reduce engine movement during acceleration. The motor mounts are direct replacement of the factory units but weigh 50% less. All necessary hardware is included. Say good bye to the wheel hop and experience smooth acceleration with Boomba Motor Mounts.
Email us if you have any questions! sales@boombaracing.com
~Dan~
Old Mar 2, 2011 | 09:24 AM
Evo X/Ralliart 75mm Throttle Bodies @ Boomba Racing Inc.
We now have in stock and ready to ship our 75mm throttle bodies for the Evo X and Ralliart!
Boomba Racing Evo X and Lancer Ralliart 75 mm throttle body is a direct replacement of the factory unit. Boomba 75 mm throttle body comes as a kit including stock manifold adaptor plate and 60 mm hose adaptor, which allows installation with factory intake hoses. The kit also includes 75 mm hose adaptor and all mounting hardware. The throttle body is designed in such way that it will have to use stock TPS and servo motor.
Enlarging the diameter to 75 mm allows the increase of the throttle cross section area by almost 56% over stock throttle body. Replacing the stock throttle body with new Boomba 75 mm throttle body will increase the horse power and greatly improve engine response (even with stock pipes and turbo). Boomba 75 mm throttle body provides limitless possibilities of increasing engine power when combined with larger intake hoses, aftermarket intake manifold and larger turbo.
Throttle bodies are CNC machined out of billet aluminum. Parts are available in natural aluminum, red, blue and black anodized finishes. All parts are manufactured to our legendary high quality standards and backed up by our warranty.
Prices on our website:
~Dan~
Old Mar 31, 2011 | 05:15 AM
Bump it to the top!
We still have all these great products IN STOCK and ready to ship!
Boomba Racing
Jun 5, 2015 12:14 PM
Boomba Racing
EvoX 'For Sale' External Engine / Power
Dec 23, 2013 03:04 PM
Boomba Racing
Dec 23, 2011 05:00 AM
Boomba Racing
Midwest Region
17
Jan 3, 2011 12:05 PM
Boomba Racing
Jul 5, 2009 08:17 PM
