ETS Mitsubishi Evolution X Intake - No Rescaling/Tune Required!
Old Jun 10, 2011 | 09:06 AM
ETS Michael's Avatar
The ETS MAF Intake Includes a huge 5" inlet K+N air filter which feeds the intake pipe via the ETS EVO X MAF adapter which is milled on the ETS lathe for the perfect transition to the inlet diameter of the MAF sensor tube. With a built in dowel pin and precise inner diameter to make a 100% seal with the rubber grommet, this piece installs and fits as if it had a Mitsubishi part number. The system is then braced to the chassis with an aluminum bracket to ensure no movement or vibration. A single-piece mandrel bent 3" intake pipe makes the connection between the MAF and turbo with a smooth transition recirculation fitting for an easy connection to the BOV discharge.
The ETS Mitsubishi Evolution X Intake includes a 5.0" velocity stack making it the largest intake on the market. This intake has been proven to gain over 56whp when used with a manual boost controller at 22psi.
Features:
  • 5" KN Filter
  • ETS Milled MAF Adapter
  • Perfrect Transition From Adapter To MAF
  • Blow Off Valve Recirculation Tube
  • Includes heat shield to prevent idle surge.
  • BOV Vacuum Line
  • All Couplers, Clamps and Hardware.
  • +56whp when used with a boost controller @ 22psi
Link To Website: http://www.extremeturbosystems.com/E...-X-Intake.html
Before
After
ETS Michael
Nov 7, 2016 08:40 AM
Shaun@AWDMotorsports
EvoX 'For Sale' External Engine / Power
143
Jun 14, 2016 10:27 AM
