**new** spark tech drag ii sequential cdi coil on plug system
Old Mar 23, 2012 | 07:26 PM
SparkTech's Avatar
Introducing the Ultimate Ignition system for your EVO 4-9 Drag combination. If your running 50+psi/Methanol/Ethanol/NOS we have your Ignition solution! If your utilizing a standalone ecu, now is the time to convert to Sequential Ignition. Featuring Spark Tech Spec motorsports Quality Ignition coils, coupled with M&W's Drag 4 cdi Sequential cdi 250mj unit. (500mj available), Full Mil-spec wiring harness with Aerospace Mil-spec heatsleeve. Varglas ES-4400 Silicone Rubber, in addition to providing superior dielectric and thermal protection, at less weight, was developed to meet unusual fluid and flame resistance requirements. Its high temperature performance places it in a 220°C(428degF) classification. Offering superior dielectric strength, high and low temperature performance, and excellent fluid and flame resistance make it ideally suited for use in industrial instrumentation, electrical and electronic machinery and equipment; and aircraft and where its lighter weight provides an additional performance advantage. Simply put these are the Highest Quality components carefully chosen to set the bar. Let Spark Tech Ignite you into the future!
Spark Tech Sequential Ignition systems now holds the ET & MPH records in the late model Evo/CT9A platform. Actually we have held the ET record since 2008 and captured the MPH record last year. Prior to us entering the market the only PnP system available was a wasted spark system, while capable it was outdated. With all the developments in aftermarket ecu's, injectors, turbos, intake manifolds etc.. every drag Evo still utilized a wasted spark 2 channel cdi(52millijoules). We stepped up the game and brought a 4 channel (250mj)PnP system to the market...that has been 4 years now Now we have stepped up the game once more!! Don't be left behind.
**This system is ONLY compatible with standalone ecu's that support Sequential Ignition!
Old Mar 23, 2012 | 08:08 PM
ToxicFab's Avatar
Very nice, had the chance to see this is person. One word, quality.
-Collin
Old Mar 24, 2012 | 07:07 AM
SparkTech's Avatar
^Thanks Collin. Your stuff is Quality too I might add
Old Mar 24, 2012 | 05:32 PM
SparkTech's Avatar
bump
Old Jun 18, 2012 | 03:23 PM
SparkTech's Avatar
This system is making it's way into quite a few TA cars world wide. It will be installed on the TA car belonging to Nemo-racing.com this car features an all carbon fiber body with some pretty wild engineering. It will be raced in the upcoming World Time attack competition on August 12th in Australia.
If you'd like to read a little more about this build check it out here--->The most amazing Evo build from Down Under
Attached Thumbnails **new** spark tech drag ii sequential cdi coil on plug system-nemoracingtaevo.jpg   **new** spark tech drag ii sequential cdi coil on plug system-nemoracingtaevo2.jpg
Old Jul 27, 2012 | 09:40 AM
SparkTech's Avatar
Unmatched Performance & Quality. There is a reason our systems can be found on the Quickest and Fastest 4g63's/4g64's. We don't have a one size fits all..just like there isn't a one size fits all injector/cam/intercooler/Turbo etc. Our extensive knowledge will give you an advantage, contact us to see which system best suits your needs.
Old Aug 29, 2012 | 11:06 AM
SparkTech's Avatar
bump
Old Aug 29, 2012 | 02:52 PM
11secEVO7's Avatar
Can you pm price shipped to 33126 please?
Evo 8 with AEM
Old Sep 6, 2012 | 12:52 PM
SparkTech's Avatar
^done
Old Sep 14, 2012 | 07:04 AM
SparkTech's Avatar
bump
Old Sep 20, 2012 | 08:55 AM
SparkTech's Avatar
bump
Old Oct 19, 2012 | 08:14 AM
SparkTech's Avatar
Some serious 4g63 powered cars will be running this system shortly.
Old Oct 31, 2012 | 08:48 AM
SparkTech's Avatar
Bump
Old Nov 29, 2012 | 07:04 PM
SparkTech's Avatar
bump
Old Feb 27, 2013 | 08:49 AM
SparkTech's Avatar
ttt
