In House Mustang Dyno @ Boostin Performance
The Boostin Performance team is committed to providing our customers with the best products and services possible. This is especially true when it comes to our tuning, which is why we have invested in a brand new MD-AWD-500 Mustang Dyno!!
With this dyno, we will be able to provide our customers with the best experience possible, as well as providing our customers with a smooth, clean, flawless tune. More in depth drivability tuning is possible, without the distractions and risks associated with street tuning. WOT tuning is also improved in this controlled environment. We are able to compare WOT pulls, fine tune cam timing, execute 4th & 5th gear pulls, tune boost by gear while you wait, etc.
Need some maintenance work performed first? No problem. We also offer performance part sales, installations, and custom fabrication as well. We are a one stop facility that can take care of all your needs ranging from diagnosing a small issue, to building you a race car, and everything in between.
For a limited time only, schedule a dyno tune with us and we will honor our current street tune pricing. That's right.......pay the same price as a street tune but have your car tuned on our brand new Mustang Dyno.
3 Dyno Pulls - $60
3 Dyno Pulls - $60
- Open to all AWD, FWD, or RWD vehicles. With this package you'll receive 3 pulls on our MD-AWD-500 Mustang Dyno, which includes an overlay of boost and AFR on your dyno printout. There is NO tuning included with this package - this is strictly for pulls only.
- 1450cc or < injector, Maf sensor - $389 - This tuning package includes a vehicle inspection, boost leak test, and a 3 hour block of time on the dyno. Every aspect of your tune will be customized - idle, cruising, tip in, WOT, and everything in between will be optimized to work as a complete package, making the most amount of horsepower possible without sacrificing any reliability. You will receive an overlay with your boost level and AFR's on the dyno sheet. If additional time is needed, the rate of $125 per/hour applies.
- 1600cc or > injector, Maf sensor, Any size injector on Speed Density - $439 - This tuning package includes a vehicle inspection, boost leak test, and a 3 hour block of time on the dyno. Every aspect of your tune will be customized - idle, cruising, tip in, WOT, and everything in between will be optimized to work as a complete package, making the most amount of horsepower possible without sacrificing any reliability. You will receive an overlay with your boost level and AFR's on the dyno sheet. If additional time is needed, the rate of $125 per/hour applies.
- Second Map for the above 2 packages - $275 - This tuning package includes a second map for a different fuel and/or boost level. To receive this rate, both tunes must be done within the same appointment.
- SST Transmission Tune - $275 - This is for all you Evo X MR and RalliArt owners who want to take their SST to the next level. This tune is custom for each application and changes the firmness of each shift as well as the pressures applied to the clutch packs.
- Retunes - $200 - This rate applies to all cars already tuned by Devin @ Boostin Performance. This gives you a 1 hour block of time on the dyno along with custom tuning to get your new parts dialed in and working as a package. Most retunes can be done within a 1 hour block of time, but if more time is needed a rate of $125 per/hour applies. If you have changed your fuel injectors or turbocharger since the last tune, this retune rate DOES NOT APPLY.
- Retunes - $200 - This rate applies to all cars already tuned by Devin @ Boostin Performance. This gives you a 1 hour block of time on the dyno along with custom tuning to get your new parts dialed in and working as a package. Most retunes can be done within a 1 hour block of time, but if more time is needed, a rate of $125 per/hour applies. If you have changed your fuel injectors or turbocharger since the last tune, this retune rate DOES NOT APPLY.
- Complete Custom Map - $595 - This tuning package includes a vehicle inspection, boost leak test, and a 4 hour block of time on our Mustang dyno. Every aspect of your tune will be customized - idle, cruising, tip in, WOT, and everything in between will be optimized to work as a complete package, making the most amount of horsepower possible without sacrificing any reliability.
- Second Custom Map - $299 - This tuning package includes a second map for a different fuel and/or boost level. To receive this rate, both tunes must be done within the same appointment.
APM Racing
Midwest Region
149
Jan 13, 2014 11:31 AM
Boostin Perform
Midwest Region
41
Jun 17, 2013 01:40 PM
Boostin Perform
Midwest Region
Apr 14, 2013 08:07 PM
