SparkTech *PRO* NonCDI Series is here! Fits on EVO4-9
Old Dec 24, 2013 | 08:50 AM
SparkTech's Avatar
Introducing the Spark Tech Pro NonCdi Cop system. Our proven NonCdi system has been on the market over 5yrs and has often been imitated but never duplicated. It has ignited many 700+whp Evo's around the globe. To date that system has ignited the Boostin Performance "Demonette" Evo to a 9.25@156. It has also supported up to 950whp on the Kings Performance Street Evo (which also ran 9.50s in the 1/4). Backed by the best warranty on the market (2yr coverage on coils, Lifetime workmanship, Lifetime Harness).
Over the years we've had many requests for a Pro version of the NonCdi and we've finally gotten around to it. You can finally have the fit and finish that rivals our SparkTech ProCDI system.
We wanted to design a mounting plate that was functional. This Pro version utilizes the 4 oem mounting holes that previously were used to mount your oem plastic coil cover. Utilizing these mounting positions this system can be installed on all Evo's 4-9. Previously our regular NonCdi fitment were Evo 4-8 and a special one to suit the Evo 9 valve covers. The coils mount to the underside of the mounting plate with all wiring hidden under the plate. This design allows for a very clean show worthy engine bay. Wire tuck guys are going to love this system . Whenever we design something, performance is at the top of the design criteria, if it ends up looking good that's just a bonus. The abbreviated Spark Tech logo(4G63 available also) is functional, as it is cut all the way through the top of the plate directly above the tops of the coils to aid in coil cooling. This system is suitable for your Time Attack Evo, Street/Strip or your daily driver with standalone or factory ecu. It is 100% plug and play.
Systems come standard with powder coated wrinkle black mounting plate. As our introductory offer our first five customers get FREE SHIPPING! In addition to free shipping, our SparkTech Laser Design division has supplied a quality leather laser etched wallet (valued at $45) with YOUR car on the front. (See sample below)
Spark Tech's proven *NEW* EVO 4-9 PRO NonCDI System:
  • Standard wrinkle black PRO NonCDI mounting plate.
  • 2 Year warranty on coils, lifetime on harness & workmanship. (tech line: 386-675-4879 / info@sparktechignitions.net
  • 100% plug and play (genuine oem connectors)
  • 100% compatible with stock ecu & standalone ecu's
  • Tested to 954whp @ 0.20plug gap
  • Military spec heat sleeve protector on wiring, rated to 428degF
  • Tefzel military spec wire, rated to 393degF
  • All components are brand new.
  • Out performs the DLI
  • Works well with stock turbo, larger turbos & fully built evos
  • Improve idle quality
  • Accelerates smoother through RPM range
  • Expect longer spark plug life due to a more efficient spark
  • Increased fuel economy (2-3mpg typically reported)
  • Due to increased spark energy you can run more boost without spark blow out
  • Improved throttle response
  • Decreased in cruise part throttle surge.
  • Smoother dyno curve.
Polished Mounting Plate option shown in images.
Old Dec 24, 2013 | 09:09 AM
SparkTech's Avatar
Use coupon : STPRONONCDI2013 during checkout to get your free shipping and instructions for your FREE wallet!
Old Jan 6, 2014 | 01:46 PM
mchristian's Avatar
Order Placed! Look forward to seeing the new PRO NonCDI unit!!!
Old Jan 6, 2014 | 06:53 PM
SparkTech's Avatar
Thanks for being a loyal returning customer. It will be our pleasure to serve you again.
Old Jan 15, 2014 | 03:52 AM
R. Mutt's Avatar
Purchased this yesterday. Been getting a lot of p300 codes arbitrarily in the last few months. Resistance in the coils doesnt check out and looks like they're on their way out. Hopefully this resolves my ignition issues. Eager for them to arrive!
Old Jan 15, 2014 | 07:24 AM
SparkTech's Avatar
Thanks for your support. While I can't promise you it will eliminate your p300 codes. I actually had my tuner remove that code from the ecu. It has been documented that it is triggered by harmonics from the drive train. Either way you will have a new Ignition system that will be up to task for just about anything you can throw at it.
Old Jan 15, 2014 | 08:27 AM
0E3vobutt3r's Avatar
I wish i could afford this looks soo awesome
Old Jan 15, 2014 | 10:55 AM
R. Mutt's Avatar
Funny enough I disabled the periphery bit lookup myself just the other day after reading this as well. No more codes obviously but I have had ignition issues with the boost I'm running and I'm sure this will be the missing piece to the puzzle.
Old Jan 15, 2014 | 12:20 PM
SparkTech's Avatar
^Worked well for me. If I have a misfire I want to feel it don't need the ecu to tell me lol
Old Jan 15, 2014 | 12:54 PM
R. Mutt's Avatar
This is true
Old Jan 15, 2014 | 06:27 PM
SparkTech's Avatar
R. Mutt it's enroute to you
Old Jan 15, 2014 | 06:28 PM
SparkTech's Avatar
Your order is en route, you'll have it tomorrow. Thanks again.
Old Jan 18, 2014 | 07:24 PM
mchristian's Avatar
This thing is sooo sexy!!! Thanks for such great service and making a top notch product...can't wait the get the car back together.
Old Jan 19, 2014 | 08:33 AM
SparkTech's Avatar
Your Welcome. Excited to see pictures once it's installed. Sounds like your car would be a good candidate for our Showcase thread and on our website. Keep us posted!
Old Jan 21, 2014 | 08:23 AM
SparkTech's Avatar
bump
