MAPerformance Evo X Surge Tank Kit | Radium Engineering & Walbro 400lph!
MAPerformance Evo X Surge Tank Kit only $1049.99 shipped WITH PUMP!!!
If you've upgraded an Evo X fuel pump before, you're already familiar with their saddle bag gas tank design and unique siphoning system. We're quite certain that a significant chunk of drug store revenue can be attributed to the headaches encountered by enthusiasts trying to upgrade their cars while working within the constraints of this system.
Fortunately, we've got the perfect remedy. The MAP surge tank kit includes everything you need to install an external surge tank (the best available on the market in our opinion) and fuel pump in your Evo X, and thanks to the included EFI adapter fittings no fuel pump housing modification is needed. Once installed, your factory fuel pump (or whatever upgrade you've already got in there) will serve as a lift pump feeding the Radium surge tank and TI Automotive 400lph fuel pump (don't worry about the size of your in tank pump, when they aren't under pressure they flow a heck of a lot more fuel and will have no problem keeping up) providing enough fuel to consistently support 700+ horsepower on E85. Note the word "consistently" as fuel starvation in left hand turns and/or with lower fuel levels are a thing of the past!
Additionally, racers should take note of the surge tank placement which is in the rear driver's side wheel well rather than within the trunk / cabin. Be sure to check with your specific sanctioning body, but there should be no need to fabricate an additional firewall behind your rear seats when using this kit!
Included Components
Radium Engineering Surge Tank
TI Automotive 400lph E85 Fuel Pump
Deatschwerks Fuel Pump Hardwire Installation Kit
MAP Surge Tank Mounting Bracket
Fuel Fittings, Lines, and Hardware
This kit is designed for use with the factory fuel rail fittings (unless you select our optional Fuel Rail & AFPR Package) and utilizes the factory feed line to return fuel from the rail to the surge tank. An installation guide is coming soon, in the mean time please don't hesitate to contact us for assistance!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||
: MDunn@MAPerformance.com|||||
: 651-348-8811 x 107|||||
