New STM Evo 8/9/X Catch Can Designs
Old Jun 29, 2016 | 12:24 PM
4g63girl's Avatar
STM has now updated the Engine Oil Catch Cans for the Evo 8/9 and X. We now offer them all with the Brushed Aluminum, Wrinkle Black or Gloss Black Powdercoat finish.
STM Evo 8/9 Transmission-Mount Engine Oil Catch Can with 3-Port Valve Cover & Engine Block Breather
The STM Evo 8/9 3-Port Can vents to the valve cover and crankcase with direct-replacement fittings and bolts under the intake to existing transmission holes for a super clean install.
STM Evo 8/9 Transmission-Mount Engine Oil Catch Can with 2-Port Valve Cover Breather
We also offer the 2-Port design which utilizes just the two valve cover vents... but you will get 3 ports and the -6AN block off if you need to upgrade in the future.
STM Evo 8/9 2-Port Can
STM Evo 8/9 Sealed Engine Oil Catch Can
We also have a Fully Sealed Evo 8/9 Can designed to help keep vacuum on the crankcase at all times. This one has NO breather filters and includes a bung to vent to your intake pipe, or we can make your life super easy and you can purchase the new STM Vented Intake Pipe for a seamless install.
STM Evo X "Sealed" Engine Oil Catch Can
We just released the Sealed Can for Evo X which also has no filters and vents to your intake pipe, valve cover and intake manifold. If you would like us to weld the bung onto one of our intake pipes, just give us a call and we can get you everything you'll need! This can mounts right to the frame rail on the Evo X for easy drain access and includes a soft buffer so it won't scratch your paint.
The sealed Can is only compatible with the metal valve cover, but if you need to upgrade, we have you covered there as well: OEM Mitsubishi Aluminum Valve Cover
STM Evo X Engine Oil Catch Can for Metal or Plastic Valve Covers
We also offer our Standard 2-Port Vented Cans for the X's with a metal or plastic valve cover. Mounts in the same convenient place as above.
STM Engine Oil Catch Can for Metal Valve Cover:
STM Engine Oil Catch Can for Plastic Valve Cover:
If you want to run the "Sealed" Engine Oil Catch, you can always have the bung welded to one of our STM Evo X Bellmouth Intake Pipes and shipped right to you!
As always, if you have ANY questions about our parts or what's best for your set-up, feel free to give us a call!
(585) 226-8226
www.stmtuned.com
cficare68
Dec 21, 2017 08:39 AM
badev0
Feb 1, 2017 06:01 AM
im no hero x
12
Apr 30, 2012 08:45 AM
anthonyrb98
50
Sep 11, 2011 07:49 AM
