Boostin Performance September Tune Up Special!!!
Tired of maintaining your vehicle by yourself, on your back, in your garage or driveway? Ensure your car is operating at peak performance with a Boostin Performance Tune Up! Fresh NGK or OEM spark plugs are installed to ensure your vehicle is operating at peak performance. Our BP Tune Up Package also includes a boost leak test, drivetrain fluid flush, oil change, and replacement of worn accessory belts to protect against charging, cooling, and power steering issues. We'll also rotate your tires, and provide an overall Vehicle Inspection to keep you informed of other possible maintenance issues that may need to be addressed.
When you set up an appointment for a BP Tune Up in September, you'll save $60 off your entire bill.
Boostin Performance Tune Up Special Includes:
- Replacement of Spark Plugs with NGK Performance or OEM plugs
- Cleaning or Replacement of Air Filter (if needed)
- Boost Leak Test
- Replacement of Engine Oil & Engine Oil Filter
- Transmission, Transfer Case, & Rear Differential Fluid Flush (*w/ SST filter replaced if applicable)
- Replacement of accessory drive belt(s)
- Tire Rotation
- Full Vehicle Inspection includes checking brakes, rotors, suspension components, etc.
Give us a call, shoot us a PM, or stop by the shop for a quote today!
*Offer ends September 29th
Boostin Perform
Midwest Region
Sep 19, 2017 06:32 AM
Boostin Perform
Evo 'For Sale' Suspension / Brakes / Handling
54
Mar 10, 2014 08:11 AM
ak47po
Oct 4, 2007 09:30 AM
