Is your 5-speed transmission not shifting like it should?? Experiencing a grind in a gear(s), lock out or even a "notchy" feeling? These are indications that there are worn transmission parts, and its time for a rebuild.
With our Boostin Performance Transmission Rebuild Service, we'll have your transmission shifting like a dream, able to hold lots of horsepower, and can last for years! Turn around time frame for this rebuild service can be as quick as one week.
Boostin Performance Evo (8/9) 5-speed Transmission Rebuild Service Includes:
•1st Gear Synchro
•1st Gear Synchro Spring
•2nd Gear Synchro
•2nd Gear Synchro Spring
•3rd Gear Synchro
•3rd Gear Synchro Spring
•4th Gear Synchro
•4th Gear Synchro Spring
•5th Gear Synchro
•5th Gear Synchro Spring
•Reverse Synchro
•Reverse Synchro Spring
•3rd/4th Gear Shift Fork
•Input Seal
•Output Seal
•(2) Input Bearings
•Intermediate Shaft Bearing
•(2) Heavy Duty Snap Rings
•(3) Heavy Duty Roll Pins
•Re-shim Bearing Pre-load
•Internal Parts are Cleaned and Deburred
•Clean and Paint Case
For more information visit our website:Boostin Performance Transmission Rebuild - 5 Speed (Evo 8/9)
*Prices may vary upon inspection and disassembly of your transmission if additional parts need to be replaced (IE: gears, shift forks, etc).
Contact us VIA PM, by phone or email for a quote and time frame availability.
Need a transmission rebuild ? We got you covered !
