Innovate MTX-D Ethanol Content Fuel Temp Gauge
So I will be switching over to E85 soon and was looking into ethanol content gauges and went with the Innovate MTX-D Ethanol Content gauge as it seemed to be the cheapest. Didn’t see too much information on the gauge so I decided to write about it.
The gauge displays ethanol content on the LCD from 0-100 and up to a tenth of a decimal. Around the LCD there are LEDs that are divided into three color sections (green, yellow, red) that tell you the temperature of the fuel with a range of -40f to 257f and you can set the range for each color. It also comes with an analog output for both content and temperature ranging from 0-5v. According to the manual it will give you an error code of E11 which is fuel contamination or over temp. I decided to see what would happen if I ran water through the sensor and it did show error code E11 on the gauge. It doesn’t go into detail of how much contamination has to be in the fuel before it shows the error. The other error code is E10 which is sensor not connected.
If you order the kit with the sensor it comes with GM senor PN: 13577429. Im not to fond of the sensor because it doesn’t have a good way to secure it down. Then you have the harness going from the sensor to the gauge which is about 8ft, a serial cable to program the gauge (analog output, temp range), silver/black bezel, and white/black face.
I am in the process of installing so this is all the information I can share.
http://www.innovatemotorsports.com/products/psb1.php
I'm nervous about it because I can't find it documented yet. But I want to do the innovate psb-1 wideband and boost in 1. It also has a shift light. I'm not sure the shift light would fit within the cluster. I am nervous because there is almost no support as to logging and using this wideband. Vs aem. Also the buttons to change settings are on the face, which would end up in the cluster.
