Do grounding wires REALLY work?
Old Sep 26, 2004 | 08:30 PM
EVOSTEVO's Avatar
i got like 20whp and i can chirp my tires in 2nd gear after i put them on...ROSGMAKTHNWISNGSLOB...im just playing i want to get the HKS ones just to have them is only 100 bucks big deal. im not going to buy a 30k car and ghetto rig it with a DIY kit. this aint no DSM!
-Steve
Old Sep 26, 2004 | 08:38 PM
Smogrunner's Avatar
How much do the Mitsu ground wires cost that they offer at the dealerships? I won a set at a meet and they are just gathering dust in my garage.
Old Sep 26, 2004 | 08:43 PM
EVOSTEVO's Avatar
they cost 2 dollars ill give you 5 +shipping....
Old Sep 27, 2004 | 06:22 AM
jmore's Avatar
Vishnu Stickers > Grounding Wires
Old Sep 27, 2004 | 12:58 PM
ShapeGSX's Avatar
What was that PT Barnum said?
A DIY kit will work the same as the $100 HKS kit**. And if you are good, you can make it look good, too.
**To find hidden meaning, substitute "work the same as" with "not do anything, just like."
Old Sep 27, 2004 | 01:02 PM
93civEJ1's Avatar
AGREED.
Old Sep 27, 2004 | 01:34 PM
ozrmrlancer's Avatar
Check out super streets website!!!! An old turbo talon gained like 6hp, and 11tq or something close to that after they played with different ground points
Old Sep 27, 2004 | 01:37 PM
ShapeGSX's Avatar
Do you actually believe anything that Stupid Street "reports?"
"One of our largest advertizers gave us this part that costs them $10 to make, but they charge $100 for it. Hmmmm...and 20 more advertizers make the exact same part. Let me think...would they be happy if we said it was a load of crap?"
Old Sep 27, 2004 | 01:46 PM
954DRGSR's Avatar
Blasphemy!
Old Sep 27, 2004 | 01:52 PM
JeansandJacks's Avatar
what about the D-sport where they got 8awhp after putting the apexi one on the sti and it blew them all away cause they couldnt figure out why it worked?
Old Sep 27, 2004 | 01:59 PM
Cajun Power's Avatar
I found that chick get naked faster if you have a grounding kit.
Old Sep 27, 2004 | 03:55 PM
jcnel_evo8's Avatar
Anybody want to hear some 'grounded' electronics?
ok, ok, ok ... putting the puns aside ... I've just had to go through a through design review for some space electronics. We've only got in this case a couple hundred kilos of metal mass to ground against (called the spacecraft) and electronics about 10x more sensitive that we have to measure / fire off than an EVOs electronics system. The concept we employ to make sure all of the different device 'grounds' are all tied together is a very highly designed point on the spacecraft called a "star ground." That means the grounding straps that come from our electronics boards, the motors, the drive stuff, and the sense stuff all come to a central location on the spacecraft, and then that location is kept from forming a lot of 'oxides' that many not let mr. electron get to 'ground' and throw off a reading / make more noise. Yes we can oxidise stuff in space. There's not a lot of O2 up there (or we'd all be up there) but what little there is, its highly entergetic and likes to make oxides out of metal fairly quickly.
What does that mean in the car world? Most of the time the car body (chassis and motor block) is considered ground. So for the most part if you get a good strap to connector to chassis connection you've done about 98% of the work. When you're sold a 'grounding' kit, they try to get a 'star' ground type connection like in the spacecraft. It helps, but I've found that with modern sensing technology and good drive electronics (ie your knock sensors and o2 sensor to say the least, and the coil drivers) you really don't "need" a grounding kit / star ground on a car / the EVO. If anything ... make sure your ground wires are tight / not developing rust, and you're halfway there.
Good Luck,
jcnel.
Old Sep 27, 2004 | 03:57 PM
I did not notice much of a difference either, but when I origanally asked this question a while ago thats what I was had read. So I did not say I believed ot or not, Just check it out jack***
Old Sep 27, 2004 | 05:24 PM
rebelzx's Avatar
They've been tested before (with voltmeters) to hold a more constant, higher voltage.
Old Sep 27, 2004 | 05:42 PM
jcnel_evo8's Avatar
Uh, if you could define how holding "a more constant, higher voltage" refers to grounding?
Thanks,
jcnel.
