XEDE installed, question
Old Oct 11, 2004 | 06:42 AM
93civEJ1's Avatar
Do you guys ever get like a hiccup or anything from your car after having the XEDE installed? I was told this is probably the ECU from the XEDE map and switching back and forth in between stock and the XEDE. I had an SAFCII before this, but never noticed any type of stutter or anything before. This weekend was the first time it had done it, but hasnt done it anymore. No CEL or anything just a little hiccup the other night.
Old Oct 11, 2004 | 06:56 AM
Smogrunner's Avatar
No. That problem sounds much more like a aftermarket blow off valve or intercooler. Since installing my AMS intercooler, I notice a very faint increase in off-throttle hiccup. I know you don't have a stock intake, so it could be that as well.
Old Oct 11, 2004 | 09:43 AM
Jaylenospoolboy's Avatar
Smog,
Did you dyno the AMS? Any gains?
(sorry about the hi-jack)
Smogrunner's Avatar
No. Not yet. Now, back on topic.
Old Oct 11, 2004 | 11:14 AM
Ludikraut's Avatar
Mine "hiccups" when I'm cruising at partial throttle at around 3K rpm and let off the gas (esp. in 5th gear). Has done it ever since installing the XEDE ... to remedy the problem, I've learned to be gentler with my foot ... or cruise at higher rpms
l8r)
Old Oct 11, 2004 | 11:34 AM
93civEJ1's Avatar
l8r)
thats exactly what mine did. The exact same.
Old Oct 11, 2004 | 01:45 PM
KZEVO's Avatar
Very interesting... Mine does the exact same at 3000rpm at part throttle...the hicups u guys have is a misfire. mine threw a CEL only once and doesn't now. it's usually a constant misfire around 3000rpm.
I thought i was the only one with this problem but that does not seem to be the case now.
Do you both have Xede Flash? I just have the Xede, Xede Flash and Turbo back. I wonder if it's the flash causing this misfire issue. Waiting for Shiv to return to figure out the issue.
I'm lost as we've put in a new Xede and drove w/o Xede to trouble shoot and it misfired (or Hiccup) so now i can only think it's probably the reflash.
Old Oct 11, 2004 | 03:10 PM
Jorge T's Avatar
Mine hicups when I let off cruising in 5th below 3k rpm
Old Oct 11, 2004 | 03:19 PM
shiv@vishnu's Avatar
Anyone having firmware version 1.7.14 (see diagnostic menu in xmap) can adjust the load bypass below which the XEDE goes completely pass through. Those with this firmware version are automatically set to 5% so that the XEDE isn't completely invisible during cruise conditions. Any hiccuping that you are experiencing is going to be caused by something else. With older firmware versions, the MAF signal isn't replicated as smoothly as we wanted so engine smoothness at ultra low loads (nearly engine braking) was compromised. XEDEs have been shipping with 1.7.14 for quite some time. If you need an upgrade, just send it in.
shiv
Old Oct 11, 2004 | 03:22 PM
Jorge T's Avatar
Ok, i stand corrected ...then its the New MR DV in my case, I had never noticed this until Saturday
Old Oct 11, 2004 | 03:42 PM
KZEVO's Avatar
Shiv - Thanks for replying. I think i have the most up to date version so I might be back at square 1. I just thought it was interesting to see some other ppl experiencing the same problem which now turns out may have been due to something else (ie BOV). Anyway, thanks the help. I'm going to take this offline and talk to you when you get back. Enjoy your trip.
shiv
Old Oct 11, 2004 | 03:45 PM
jj_008's Avatar
I have had my XEDE for 5 months, with the newest firmware, and have had no problems.
Old Oct 11, 2004 | 03:46 PM
93civEJ1's Avatar
Ive had mine since last weekend. The car is starting to feel slow to me again. But yeah, mine was just thta one time. I guess since I just got my XEDE at dyno4mance last weekend that i should be up to date.
Old Oct 11, 2004 | 03:59 PM
KZEVO's Avatar
Funny how it feels slow cuz that's what i was thinking too after a week. First i was like this is the shiat after I got the Xede and now i want more...i don't know where the F my stupid Cams are ... hopefully in a couple weeks
Old Oct 11, 2004 | 04:00 PM
Dyno4mance's Avatar
It sounds like you are just getting used to the car, I have thought mine had slowed down but I have verified the power is still the same on the dyno time and time again.....do you have a boost gauge?
Is the light on the top of the xede green when driving?
