Blitz Induction cover and HKS Panel filter
Old Oct 13, 2004 | 08:15 PM
Ted B's Avatar
In theory, many things seem like they would work better, especially when they look like a million bucks. In reality, it's a crapshoot more often than not. The proof of the pudding is in before/after dyno numbers with A/F logging to determine what (if anything) is really happening.
Without that, it's pure speculation.
Old Oct 14, 2004 | 09:02 AM
digitaltekniq's Avatar
how do you figure?? its the EXACT same design as the stock intake but with a larger surface area filter and a larger ram intake design...plus it doesnt have the seperator in the middle of the ram extention piece
Exactly...it's the exact same design - slighter larger intake, and no separator. I would surmise that counts up to a .5% improvement in overall HP.
Old Oct 14, 2004 | 09:12 AM
Ludikraut's Avatar
I'd even take it a step further than that, because I don't believe you can really test the effectiveness of a ram intake on a dyno. The only way to really test it would be on the road with AFR logging. Anytime you change the intake configuration you need to log AFRs and if you really do end up with a more efficient intake, then I can pretty much gaurantee that you will have to retune your car to accomodate the new airflow.
Also, if you really look at how the stock piece is designed, I don't think the HKS piece offers much of an improvement. For example, just looking at the pic, I don't see the foam cushions on the HKS piece, which will allow more air to bypass it.
l8r)
Old Oct 14, 2004 | 12:55 PM
EVOtagger's Avatar
that was my point...exact same design as the stock intake, but with more airflow...the stock intake is a good piece and is designed properly...the way an intake should be designed...but it lacks airflow...hense why this intake is better IMO
and your .5% HP surmise is based on what?
Old Oct 14, 2004 | 12:58 PM
EVOtagger's Avatar
I realize that not much can be derived from one simple picture...i would like to have the part in hand and do some testing on it...which is why my original post said
Originally Posted by EVOtagger
any testing done with this intake??
i guess ill have to be the one to test it out since no one else seems interested in its design
Old Oct 14, 2004 | 08:52 PM
Do you have an intake volume/flow resistence comparison between the stocker and this? Just a question. Don't forget that the MAF is going to be unhappy with the change in flow.
I was kidding around 99% of the time, without the appropriate tuning for an intake they yield very little real world performance. Really, it's only the last thing to do when you've done everything else (like turbo, intake manifold, downpipe, exhaust housing etc).
Don't get me wrong, intakes can help in instances where the factory air intake system is poorly designed or inadequete. However, there are much better ways of generating horsepower. If you're doing this for underhood bling/clearing up some space for something else in that area (like a catch can) - go for it.
Lastly, AFAIK the stock airbox has no problem supplying enough air for 350WHP - unless your WHP goals are higher than this I would save the money and spend it on something else like cams or gears (without your mod list I don't know if you've already done this).
Whatever you decide - enjoy
Cheers
Rich
Old Oct 14, 2004 | 08:58 PM
Ludikraut's Avatar
The Vishnu red beast was making 560+whp using stock airbox....
l8r)
Old Oct 15, 2004 | 08:59 AM
Nuff said..
Old Oct 15, 2004 | 09:53 AM
EVOtagger's Avatar
nope...which is again why i asked if anyone else had any figures for this intake
it never hurts to add performance and bling at the same time
yea we can get into which mods are better in which order and whatnot..but since this thread was about an induction modification, i figured ide throw this intake out there since i have posted about it in a couple other threads...but no one seems to be able to show any figures on this setup...
of course cams and gears are up next for me...but this airbox is a possiblity down the road...and it never hurts to have numbers to back up the $400 you just dropped on an intake
Old Oct 15, 2004 | 11:22 AM
That's true
Old Oct 21, 2004 | 11:23 AM
RenoEvo's Avatar
Vishnu car making 560whp? In the car and driver super car challenge it said it was only making 475 at the flywheel
Old Oct 21, 2004 | 06:21 PM
Ludikraut's Avatar
That was on 93 octane. 560+ = racegas tune.
l8r)
noypiC50
22
Apr 22, 2011 07:29 PM
evo9801
Mar 27, 2009 05:24 AM
urBan_dK
Northwest Region
12
Apr 16, 2008 07:44 AM
Black Ninja
Nov 7, 2007 09:30 PM
Mach 8
Nov 23, 2004 04:05 AM
