Hidden Expenses
Old Oct 13, 2004 | 03:30 PM
EVOFREAK's Avatar
Hidden Expenses
Ok so I have a Vishnu Stage 1 Sig(Cams, Piggyback ECU, Dumbback exhaust) and I want to go to the next level. I want to port and Polish the head, bigger cams, valves, springs, retainers, ect.. I was wondering what else will I have to upgrade with all of that. I am sure I will need a fule pump but what else am I going to have to get. Clutch? Head Bolts? Diffrent head gaskett?
Thanks
Old Oct 13, 2004 | 04:27 PM
David@Vishnu's Avatar
Thanks
We/EZ76 are doing testing to see if your headwork is worth the expense on the stock turbo. Also I dont see a hotside we have gotten very good gains with that little part
Old Oct 14, 2004 | 09:16 AM
Ludikraut's Avatar
How would you rate the difficulty of installing the hotside?
l8r)
Old Oct 14, 2004 | 10:57 AM
Dyno4mance's Avatar
IMO about the same difficulty level as cams
Old Oct 15, 2004 | 12:28 AM
EVOFREAK's Avatar
What is a hotside? I feel like a noob
Old Oct 15, 2004 | 05:35 AM
Jorge T's Avatar
Hot side = 10.5 nozzle turbine housing
Old Oct 15, 2004 | 06:53 AM
UncleXSO's Avatar
Where can you get the 10.5 housing? And how much do they typically run?
Old Oct 15, 2004 | 07:10 AM
Ludikraut's Avatar
Start here: http://linux.forcedperformance.net/m...ode=Lancer_EVO
The also sell the titanium internals for your stock turbo...
l8r)
Old Oct 16, 2004 | 11:31 AM
bukhumnoi2000's Avatar
I'm asking the following questions because I'm interested and I'm ignorant IRT this upgrade.
Do you recommend this job for weekend DIY folks?
I know that installing cams is much easier if you have the timing belt tensioner tool. Does installing this part require any special tools or just a lot of time and patience?
Also - has anybody installed the completed kit of titanium shaft turbocharger/10.5 housing? If so - how difficult to install this?
Thanks so much for you time.
Old Oct 16, 2004 | 05:38 PM
Noize's Avatar
EvoM Administrator
Having been along for a few of those, I'll say that the hotside takes more cajones and more elbow grease and patience than the cams do. I'm not quite the pro Andrew is at both of them, though.
