23psi in 2nd, 24psi in 3rd??? WTF
Old Nov 3, 2004 | 07:22 PM
EVOtagger's Avatar
hit 23 psi in 2nd gear today...and then shifted to 3rd and ran up to 24psi so i let off real quick...im running XEDE with a 3" turboback catless exhaust...stock intake, Worx BOV (recirculated)..
running the downpipe 93 map from the vishnu site...should i just adjust my boost table?? if so, under what loads and rpm do i need to lower?? i want to run safely, but i dont want to give up power...or are these boost levels safe??
any help would be much appreciated!!
also, shiv if you see this...whens the next time you will be on the east coast...either at turbotrix or dyno4mance? i need a custom tune and an Xflash (dont want to mail out my ECU)...thanks!!
Old Nov 3, 2004 | 11:36 PM
IE Evo's Avatar
As long as it drops after the initial spike you are okay I think. If not alot of us are in trouble. It should go down and taper after that before holding I believe. Don't worry be happy.
Old Nov 4, 2004 | 02:17 AM
David@Vishnu's Avatar
Also guys running non stock DVs and non customed tuned need to pay heed to boost
Old Nov 4, 2004 | 06:34 AM
EVOtagger's Avatar
yea i was spiking 22psi with the stock DV...should i adjust the boost table until i can get a custom tune?
Old Nov 4, 2004 | 09:18 AM
gnulooks's Avatar
Don't worry too much about it, I hit 23-24 PSI all the time.
Old Nov 4, 2004 | 11:07 AM
Ludikraut's Avatar
I hit 22-23psi in 1st - 3rd and 24psi in 4th and 5th ... custom tune with Greddy Type-S BOV
l8r)
Old Nov 4, 2004 | 11:52 AM
snoop's Avatar
Spike at 23PSI but it tapers to around 18PSI at redline
If you were to keep 23PSI to redline you will hit fuel cut if don't have a xede flash.
Old Nov 4, 2004 | 02:05 PM
XLR8R's Avatar
i hit 22-23 all the time (Cali 91 octane, custom tuned by Shiv), you can hear the Xede going nuts with the clicking. Don't really have time to look at the boost gauge to see the taper since 5500-7000 goes by in a flash
Old Nov 4, 2004 | 03:05 PM
EVOtagger's Avatar
ok thanks for the info fellers
Old Nov 4, 2004 | 06:42 PM
EVOtagger's Avatar
nope hit boost cut tonight...will have to detune
anyone on the east side that can tune XEDE?
Old Nov 4, 2004 | 07:47 PM
watchout's Avatar
you will tend to hit higher boost pressure in your high gears do to the fact that there is more load on the engine.
Shane
Old Nov 4, 2004 | 10:01 PM
Ludikraut's Avatar
Get the XEDEflash to get rid of your boost cut (along with a few other things)...
l8r)
Old Nov 5, 2004 | 09:21 AM
EVOtagger's Avatar
Shane
i know...this is my 3rd turbo'd car
but i am hitting high boost in low gears which is what worries me a bit...i will have to detune for now until i can afford to go without my car for a few days (sometime over x-mas break)
Old Nov 5, 2004 | 09:54 AM
shiv@vishnu's Avatar
To bring boost down a bit, simply reduce the numbers in the boost table. Easy way for non-tuners to do this is to select the whole table and right click your mouse. Select "Add offset" and input "-10". This will reduce your boost by 2psi or more. If it is too much, do it again and input "5". This will add a bit more boost. Those tuners out there can take it a step or two further by adjusting only the offending rpm zones. They can also add a bit of closed loop-like boost control by reducing the duty cycle values just above the regions that you run through. So just in case boost moves higher than usual, the lower duty cycle in the higher cells will bring it back down to normal levels. To see what cells you go through, simply select/highlight the entire map and run your car hard under boost. The active cells will turn yellow.
Cheers,
shiv
Old Nov 5, 2004 | 10:23 AM
EVOtagger's Avatar
sweet makes sense...now when are you coming to the east coast?? i need a tune and a flash
