P0243 Code on start of car
Old Apr 15, 2006 | 02:38 PM
MENTY's Avatar
wrong empty slot??? I am still getting 22lbs fo boost!!!
Old Apr 15, 2006 | 04:12 PM
Spec'd's Avatar
Originally Posted by shiv@vishnu
Sounds like you extracted the wrong green wire. Either that, or pushed in the xede harness's terminal into the wrong empty slot.
Old Apr 15, 2006 | 05:20 PM
MENTY's Avatar
the light green wire the third one it like on the picture is the one that i took out . I know i got the right one. would the boost work if you got the wrong one??? cause the boost is fine it doesnt do it on every start up
Old Apr 15, 2006 | 06:45 PM
shiv@vishnu's Avatar
You could still be seeing 22psi of boost with the wrong wire pulled out. That would be because you are still running the factory boost control system with the pill removed. To see if you hooked up your boost control wires correctly, zero out your boost table and see if boost falls to 10-13psi. If it does, you extracted the correct light green wire. But this does rule out that you inserted the other wire into the same slot the light green wire came from. If you put it in the wrong slot, you will throw a wastegate CEL.
-shiv
Old Apr 16, 2006 | 01:15 PM
MENTY's Avatar
Well I am on the sixth startup without a light. I took all the plugs out and replugged them all back it and it works now. Hope it stays off. Thanks for everyones input....Bob
Old Apr 16, 2006 | 01:23 PM
Old Apr 17, 2006 | 02:48 PM
MENTY's Avatar
Well lucky number seven and ITS BACK!!! I dont know if there is a bad connection of what. And yes twice before the unit flashed red or yellow and the boost was in the teens. So I definately got the right wire. We did have to cut and solder the wire cause we could not get the wire out of the slot could this do it???Thanks Bob
Old Apr 17, 2006 | 03:10 PM
SuperHatch's Avatar
Menty... PM me your phone number, I will talk you through the diagnosis. I had this very same problem not too long ago.
Old Apr 18, 2006 | 08:26 PM
MENTY's Avatar
Question: When u remove the pill from the line, do you just plug that line back in??? I noticed that passive boost thing and that should only be for the 05 correct??
thanks
Old Apr 19, 2006 | 07:54 AM
SuperHatch's Avatar
Just talked to Menty, I think we have the problem figured out, I'm sure he'll update....
Old Apr 19, 2006 | 08:25 PM
MENTY's Avatar
Still have the problem could it be a bad board that u discussed superhatch??? I hav eto go over the wires just once more I am going to freak out!!!
Thanks
Bob
Old Apr 20, 2006 | 04:24 AM
SuperHatch's Avatar
Shiv & Co....
Menty's problem is this...
The XEDE IS controlling boost properly.
The ECU is not getting a "dummy BCS" signal from the XEDE.
He had a problem removing the green wire from the ECU plug, so instead of removing it, he cut it and soldered the corresponding ends to the wires on the XEDE, so his connections are good.
He did however go at that ECU plug pretty good with a small screwdriver trying to get the terminal out before going the cut/solder route. We theorized that he could have bent the terminal inside the ECU plug and is not getting a connection tripping the P0243 code. I told him to make sure that terminal was ok.
He did and he is still getting the code, is it possible that he has a bad XEDE harness???
Old Jul 8, 2006 | 07:43 PM
RogueSTi's Avatar
BUMP...
Now Im getting this problem. I got it once with the Xede connected and now once with the Xede removed.
I removed the Xede to send it in (for a different firmware problem) and I get the code WITHOUT the xede installed. I will go verify that I put the green wire back in the correct place.
nobullevovii: Did you figure it out??
Old Jul 8, 2006 | 07:48 PM
Spec'd's Avatar
Originally Posted by Evillusion
BUMP...
Is it boosting higher and did you reinstall the pill ?
