Need some serious help
Old Nov 24, 2004 | 03:48 PM
  #31
Dyno4mance's Avatar
Good picture although that looks blue
edit....doh...I guess thats after you installed the xede huh?
Old Nov 24, 2004 | 03:59 PM
  #32
n00dle's Avatar
Yep.
One of these days I'll get one from the other side. Hopefully with enough detail to see the clip to release the wire.
Old Nov 25, 2004 | 09:50 AM
  #33
edtxag's Avatar
is the wire kind of blueish green? because there is a blue wire by your thumb but you were talking about the one on the top by the teeth the third one from the right which looks aqua in that picture right?
Old Nov 25, 2004 | 11:11 AM
  #34
tcarretti's Avatar
Edgar,
Are you still having problems hooking up the XEDE? I tried to call you with the phone number you gave me for your cell but it doesn't seem to be working. I was going to come take a look and see if you had the wires hooked up correctly. Anyway, just checking on you, hope it's all going well. I'm going to be at my parents house this afternoon but if you want to give me a call, my cell is 210-313-3331.
Tony with the White RS and Vishnu Stage Zero
Old Nov 25, 2004 | 02:14 PM
  #35
n00dle's Avatar
Correct. If you pay attention to the housing orientation and the release clip you can locate it without worrying about colors.
Old Nov 25, 2004 | 08:34 PM
  #36
Mistasparkle's Avatar
Hey man maybe i can help.
I had this EXACT same problem. turns out i pulled out the wrong green wire. long story but i damaged the other green wire which is the throttle sensor wire or something. (hence why you have to give it gas to start). put everything back to stock in regards to the ecu and start again, and make SURE you have the right green wire!
Off topic: my OTHER green wire wont even go into the hole anymore. is there any way to put it back into the damaged socket with some kind of glue? thanks
Old Dec 1, 2004 | 04:38 PM
  #37
edtxag's Avatar
Ok here is an update on my situation. I ended up getting my car sent to the shop, figured it was beyond my skills. I talk to the shop every now and then and the little they seem to be looking at my car he says it is giving him a crank sensor error, a cam sensor error, and a speed sensor a error. now i wonder could i have thrown these way off when i did a cam install? it was done by my friend who has done this plenty of times and i still dont think we did anything wrong. the xede might not be an issue i am thinking of removing it for the time being and just telling the guy to get my car up and running before i mess with the xede after all this should just smooth out my ride and give me higher gains which i dont need right now i just need it running. anyways what do you all think??
-ED
Old Dec 1, 2004 | 05:01 PM
  #38
edtxag's Avatar
oh yeah i was also told that my #'s 1 and 3 cylinders are firing at the wrong time
