Exede Map Switching
Old Dec 15, 2004 | 01:53 PM
Dyno4mance's Avatar
Originally Posted by gsujeff55
uh, i didn't think it would swap maps without turning the ignition off.....
Why not?......
Old Dec 15, 2004 | 02:33 PM
jfh's Avatar
jfh
Originally Posted by Dyno4mance
I know....you've told me .....our switches are logical though...up is for more
down is for less
I have a simple toggle switch mounted up under the dash. Easy to get to while driving if you know where it is. I wired it like Andrew described....up is for more...down is for less.
Old Dec 15, 2004 | 06:43 PM
Jorge T's Avatar
Originally Posted by shiv@vishnu
I don't like switches... so there!
I always use male/female connectors since customers (and I) can't forget which way is ON and OFF
Shiv
I just ditched my switch for the connectors...guilty as charged!
Old Dec 16, 2004 | 09:19 AM
evolute's Avatar
i like the idea of a switch and i've always assumed you could hook up an LED to know if your 'race map' is on or off - i mean, hey, it's not every piggy-back ECU that will switch maps on the fly (with the car running); so why not take advantage of it even if you hardly ever use it?
but i didn't know an 'up/down' type switch would work? they work just fine i guess?
Old Dec 16, 2004 | 04:46 PM
sspeed's Avatar
Question
In the installation instructions it says that after connecting the wires, or flipping the switch to switch maps, the light should go orange for a second or two. When I try this, it stays solid green the whole time without even a flicker. Does this indicate a problem?
Old Dec 16, 2004 | 07:40 PM
Jorge T's Avatar
Do you have a map on each bank? Mine does go from green to orange to green when I plug or un-plug the wires. I verified this 2 times today.
Old Dec 17, 2004 | 08:56 AM
sspeed's Avatar
Yes..I do have a map in each.
