Exede Map Switching
Old Dec 14, 2004 | 09:41 PM
KillaSweep's Avatar
Exede Map Switching
Hey there...I'm about to order an Xede and was just getting some parts and stuff together. For the map switching on the Xede do you just need a simple on/off 12v toggle switch? How is it wired? Thanks!
Old Dec 14, 2004 | 09:55 PM
Smogrunner's Avatar
Hey you don't need anything. In fact, I personally don't think switches are such a good idea as they can be accidently flipped. I just put a male/female connector at the end of each wire and they have a plastic shields to keep them from accidentally touching. Apart = pump gas, together = race gas.
Old Dec 14, 2004 | 10:19 PM
gsujeff55's Avatar
what he said.
Old Dec 15, 2004 | 10:07 AM
snoop's Avatar
Talking
Originally Posted by KillaSweep
Hey there...I'm about to order an Exede and was just getting some parts and stuff together. For the map switching on the Exede do you just need a simple on/off 12v toggle switch? How is it wired? Thanks!
Andrew at DYNO4MANCE installed a switch on mine Go with the switch. Maybe Noize or Andrew can comment on the type of swicth they mounted in there cars. There is small hole in Metal piece above the stock ECU that can fit the switch. I don't no were they got the switch. No chance of accidently flipping since it behind the glove box.
Old Dec 15, 2004 | 10:38 AM
Dyno4mance's Avatar
Better by design
Everyone likes a switch smoggie....an out of sight go baby go switch, a mad max type auxillary rockets to powa switch.....goes with the bling doesn't it?
Old Dec 15, 2004 | 10:47 AM
shiv@vishnu's Avatar
I don't like switches... so there!
I always use male/female connectors since customers (and I) can't forget which way is ON and OFF
Shiv
Old Dec 15, 2004 | 11:10 AM
Dyno4mance's Avatar
Shiv
I know....you've told me .....our switches are logical though...up is for more
down is for less
Old Dec 15, 2004 | 11:18 AM
snoop's Avatar
I flipped switch to 93 and forgot I did and got some hesistation with 91 gas so flipped switch while I was still driving. I love hittin switches
up 91
down 93
Now was that hard
Old Dec 15, 2004 | 11:25 AM
Dyno4mance's Avatar
up 91
down 93
Now was that hard
I suppose that proves Shivs point....you can't count on everyone doing as they should...people are a nightmare
Old Dec 15, 2004 | 12:13 PM
KillaSweep's Avatar
I found a military style 12v arming switch with the safety cover...then the switch below has a built in LED that is on when the switch is in the "armed" position....seems like that would be pretty helpful
Old Dec 15, 2004 | 01:28 PM
gsujeff55's Avatar
up 91
down 93
Now was that hard
uh, i didn't think it would swap maps without turning the ignition off.....
Old Dec 15, 2004 | 01:38 PM
KillaSweep's Avatar
Just ordered my Xede!
Old Dec 15, 2004 | 01:44 PM
Eric Lyublinsky's Avatar
Shiv
Ya I do to
Old Dec 15, 2004 | 01:50 PM
Terry S's Avatar
Congrats!
Old Dec 15, 2004 | 01:52 PM
Ludikraut's Avatar
Just get a two position switch with a key (LED for on is a good idea also) ... looks cool and no accidental flipping of the switch.
l8r)
