Anyone in Chicago with Xede?
Old Jan 13, 2005 | 10:59 AM
hkfeet's Avatar
I might need some help with my install, I couldnt get my car to start, and probably used the wrong wire for boost control. Anyone nice enough to help a evo brother out? Thanks !@
Old Jan 14, 2005 | 02:50 AM
hkfeet's Avatar
Nobody huh, sigh.
Old Jan 14, 2005 | 07:53 AM
gsujeff55's Avatar
try in the regional forums. or try to do it yourself again.
Old Jan 14, 2005 | 08:20 AM
Ludikraut's Avatar
I might be able to help out over the weekend - I live in the SW burbs... AMS in Schaumburg could also install it for you. Should take them less than 30 minutes...
However, did you download the instructions from the Vishnu site? (http://www.vishnutuning.com/files/ev...directions.pdf OR http://www.vishnutuning.com/xede_evo.htm) Other than getting the "correct" boost wire, also make sure that you have a good ground. There's a good ECU pinout diagram at RRE's website (http://www.roadraceengineering.com/e...-ecuwiring.htm).
l8r)
Old Jan 14, 2005 | 01:02 PM
Evol_I's Avatar
l8r)
Thanks for the heads up on the ECU pinout diagram... But do you happen to know what RRE calls the 'boost control wire'( from the Xede install info )?
Old Jan 14, 2005 | 01:45 PM
Ludikraut's Avatar
IIRC, it's pin 11, the "Turbo Wastegate Solenoid". Double check here on the forums, though, it's been discussed before. (sorry I'm too lazy to hunt for it ... got work to do )
l8r)
Old Jan 14, 2005 | 01:53 PM
Evol_I's Avatar
That was my first guess, too! I will confirm with the gurus @Vishunu when my Xede arrives. Thanks!
Old Jan 14, 2005 | 03:17 PM
donour's Avatar
I'll be driving through your area in a few minutes.
EDIT: driving through with a correctly working xede.
d
Old Jan 14, 2005 | 03:25 PM
David@Vishnu's Avatar
Thanks for the help seasoned Chi town xede guys!
Old Jan 14, 2005 | 03:48 PM
AMS97EclipseGSX's Avatar
If you still have issues call us at the shop. We would be glad to help you. 847-709-0530 Ask for Micah or Eric
Old Jan 14, 2005 | 03:55 PM
donour's Avatar
See look at that? Three helping hands all within 30 minutes.
d
Old Jan 15, 2005 | 09:46 AM
AMS Rocks for sure
Old Jan 28, 2005 | 07:33 PM
hkfeet's Avatar
Ahh I forgot to update this thread. Apparently my harness was bad and I had used the correct wire. Vishnu sent out my replacement yesterday and I was able to get my xede hooked up and running today. So far so good, thanks for the help donour, ams, david!
