Vishnu Stage 1+ equivalent car spark plug question
Old Jan 24, 2005 | 06:30 AM
alleggerita's Avatar
Originally Posted by GTVEVO
The P stands for Pretruding(think thats how you spell it) basically the plug with the P is hotter so the BR8ES is really 1.5 ranges colder than the BPR7ES.
What he said. While a projected electrode is less prone to fouling it is more likely to produce preignition.
Old Jan 24, 2005 | 07:00 AM
Smogrunner's Avatar
Originally Posted by livesports
No one mentioned going one step colder on the spark plug when i installed my stage 1+. Is this something that was over looked? Is this something that can possibly allow for a more radical tune and therefore more power?
Should I be running out tomorrow to change my plugs from stock t BR8ES?
Thanks in advance for the answers
Scott
You're fine, no hurrying needed. If it runs fine and doesn't misfire when you are on high octane maps, then no need to worry. I went one range colder only because I was like a sheep being herded. But when you are making 125 hp more than stock it seems like a prudent thing to do. For anyone with a big turbo upgrade, it is probably mandatory to fight against misfire.
Old Jan 24, 2005 | 07:50 AM
93civEJ1's Avatar
mine seems to run fine with the stock plugs, im just anxious to see how bad they look though.
Old Jan 24, 2005 | 10:08 AM
livesports's Avatar
seems to run fine. sometimes i get a little hiccup on the race map around 6500-7000 rpm. maybe that is a misfire? I'm not sure.
why would going colder stop misfire?
what negative effect would a colder plug have?
can you ultimately tune a car to make more power on a colder plug?
are you using the bPr8es or the bR8es?
Thanks for your tie in answering these questions!
scott
Old Jan 24, 2005 | 01:57 PM
93civEJ1's Avatar
well i checked most of the 8 plugs I bought, and on my little round gap measure tool, they all seem to stop on the round gap thing at around .029-.030 When checking the gap with one of those tapered round measurers, do you slide the plug around til it stops, and then whatever the middle of the electrode lines up with is what it is gapped at? or is it just when it begins to touch the metal.
Old Jan 24, 2005 | 07:12 PM
mitsuorder's Avatar
pick up something like this, I found one at NAPA and it has made life easier http://www.handsontools.com/store-pr...%3E_25650.html
Old Jan 24, 2005 | 07:18 PM
93civEJ1's Avatar
i had thought about a feeler gauge, but felt like it wasnt needed. Im just going to be checking my spark plugs at the moment, not doing a valve job or anything like that. The round little tapered disc seem to work fine as far as I know. Correct?
Old Jan 24, 2005 | 07:22 PM
mitsuorder's Avatar
I never felt comfortable using the little round gauge to get an accurate reading, but I'm sure they're ok as many people use them.
Old Jan 24, 2005 | 08:23 PM
Smogrunner's Avatar
scott
I'm tired sooooo, I suggest you use the search button.
Old Jan 25, 2005 | 04:19 AM
Dyno4mance's Avatar
Agreed...I recommend using feeler gauges to gap plugs
Old Jan 25, 2005 | 07:47 PM
93civEJ1's Avatar
well, installed the BR8ES tonight, gapped them down to .024-.025ish, so far i really cant tell any difference if it helped anything or made anything worse, but i cant say i drove for more than 5 mins either. My stock plugs actually didnt look too bad, but seemed to be alittle more whiteish than a brown/tan color.
Old Jan 25, 2005 | 07:53 PM
Dyno4mance's Avatar
Yep...they always are, the very reason for installing the colder plugs...My 2c
Old Jan 31, 2005 | 07:25 AM
93civEJ1's Avatar
What are the stock evo plugs gapped at from the factory?? Is. .024 The biggest gap we can run before generally seeing spark blowout? seems like a pretty small gap.
Old Apr 13, 2005 | 03:17 PM
johny719's Avatar
i believe 0.028
