Cam timing question
Old Jan 24, 2005 | 11:10 AM
MR-SilverEVO8's Avatar
Question Cam timing question
OK, I have 2 questions. Just to make sure, what's the ideal number of degrees of cam retardation from the stock position of the cams in the latest model EVO?
Secondly, in which direction do the cam gears turn in relation to the camshafts to attain retardation?
Thanks
Old Jan 24, 2005 | 11:45 AM
OK, here is a sketch of the cam gear..... Is this correct?
Old Jan 24, 2005 | 11:47 AM
This woulde be looking at the camgears with the cover removed........
Old Jan 24, 2005 | 11:55 AM
Dyno4mance's Avatar
No the other way
Old Jan 24, 2005 | 12:03 PM
Originally Posted by Dyno4mance
No the other way
Thanks Andrew.
Old Jan 24, 2005 | 12:57 PM
SuperHatch's Avatar
Aww... he drew a cam gear in Solidworks
Old Jan 24, 2005 | 01:05 PM
Close but no cigar..... Try ProE
Old Jan 24, 2005 | 01:13 PM
SuperHatch's Avatar
Funny since I use both programs every day, the gradient background made me think Solidworks, do you use Wildfire 2.0?
Old Jan 24, 2005 | 01:26 PM
A418t81's Avatar
Yeah, just think about it as far as how the motor spins. When you are looking at the "front" of the motor (side w/ the cam gears) the gears, crankshaft, etc will all spin clockwise. If you rotate the inner part of the gears clockwise, you'll advance and vice versa.
Old Jan 24, 2005 | 01:29 PM
KLancer1997's Avatar
Thought the same thing until I noticed the coordinate system note towards the bottom.....never seen that in SW before
Old Jan 24, 2005 | 01:37 PM
Yeah, Wildfire 2.0 it is..... Sometimes I wish it worked like the previous version, I'm having problems patterning the cuts for the teeth..... I can only get 9 copies without screwing up the pattern. In that picture I made 9 patterns to the right and mirrored them to the left.... I just can't get the hang of this wildfire in some ways
