Shiv, or anyone..cold weather Xede help?
Old Jan 25, 2005 | 04:32 AM
Toddevo 8's Avatar
leif, on the dyno the stock are box work fine. I had the hks rs kit and only gained 2hp. so I would say stay with the stock air box.
Old Jan 25, 2005 | 05:39 AM
SuperHatch's Avatar
Originally Posted by leif
i heard a dynoflash is better cuz you can use an intake.
I think this guy was joking, cause I was LMAO
Oh, and yes, you can run higher levels of boost safely with 0+ mods, but I would really look into a fuel pump if I were you. Cheap insurance.
Old Jan 25, 2005 | 06:07 AM
VTECH8TR's Avatar
Originally Posted by evoland
take out glove box. Unplug xede. Put glove box back in place. Throw xede in trash. Get utec. Problem solved.
HAHA... LMAO
Old Jan 25, 2005 | 06:28 AM
Dyno4mance's Avatar
Originally Posted by KillaSweep
This is probably a stupid question, but say i do get the XedeFlash....it raises the boost cut, but will it be safe to run that kind of boost with only stage 0+ level mods and the stock fuel pump? I just don't want to lean it out and blow something up or something you know? I guess i;m just asking a lot of questions so I do the right thing
You will be fine at 0+ with an xedeflash and no pump although as others have said for $100.00 it wouldn't be bad to install a pump to lay a foundation for further mods ....is your car an 03/04?
Old Jan 25, 2005 | 09:44 AM
KillaSweep's Avatar
Yep my car is an 03. I will probably get the walbaro just to be safe. I've actually had 2 other stock fuel pumps fail in the past for unknown reasons when the car was completely stock (minus a greddy BOV). What kind of boost is safe for a 93 octane stage 0+? Just so I have some sort of reference what to shooot for...and what to avoid.
Old Jan 25, 2005 | 09:47 AM
KillaSweep's Avatar
i'll end up with the pump eventually because my final goal is stage 1+.....once I can "master" that power at the track (road courses) then I'll worry about more power. Hahaha.....with the added power I'm going to need better brakes...i wouldn;t doubt that I gained 10-15 mph on the straight the way this thing is pulling.
shiv@vishnu's Avatar
Yep.. lief was joking. That subtle british humour of his
Old Jan 25, 2005 | 09:49 AM
Alright...well great, but that still doesn't answer my question and the whole reason I even started this thread. I was simply asking for suggestions and what to do to compensate for cold weather. Shiv, is the suggestion about lowering boost between 3500-4500 a good place to start? It seems like i'ms hitting boost cut closer to 5000
Yep... just drop the boost in that range a few points and you'll be fine.
shiv
Old Jan 25, 2005 | 10:10 AM
KillaSweep's Avatar
haha alright.....thanks shiv...I think I've about got it worked out perfect. You guys going to be traveling anywhere close to Indiana anytime soon...or this summer? I'd love to get a custom tune like one of my friends got...it was crazy.
Old Jan 25, 2005 | 06:41 PM
leif's Avatar
Originally Posted by shiv@vishnu
Yep.. leif was joking. That subtle british humour of his
im glad some people caught on
