BOV, Shiv?
Old Feb 4, 2005 | 08:30 PM
EidolaDream's Avatar
sounds good, im not wanting to get a new BOV unless I have too.. I just dont want to deal with the issues people are haveing with them.
Old Feb 4, 2005 | 08:44 PM
DDDEVO's Avatar
Talking
What about the 1g all metal..have seen a few people with that one and no problems..but don't see alot of people on this board talking about it. Everyone's input would be helpful. Am running this one in my 98' GST..seems to work fine.
Old Feb 6, 2005 | 07:15 PM
hmm not sure but I talked with vishnu again and they told me the the forge recirce BOV is the one they use.. On a side note has anyone seen the new greedy type rs? Not sure if you can recirc it. But it looks purrrrdy..
Old Feb 6, 2005 | 08:01 PM
jj_008's Avatar
I run the Forge w/ the yellow spring and it works very well.
Old Feb 7, 2005 | 06:55 AM
Dyno4mance's Avatar
^^^ this does not surprise me
I have found that a lot of owners want the valve to stay shut and "hold boost" ....
Because this is the mindset the first logical step would be a really strong spring right?
I have found that the area that needs addressing is the transition between pressure and vaccume...the softer the spring the more easily the valve is able to transition...this ease of tansition eliminates compressor surge...because the valve is able to quickly evacuate pressure from the system when the throttle is closed.
I have found that a weak spring does not mean boost leak...In fact the force that holds the valve shut under boost is mainly done by the small pressure line at the top of the valve....so under boost the pressure either side of the valve is nearly equal..requiring only a small amount of spring pressure to maintain a seal.
Old Feb 7, 2005 | 07:52 AM
crusin_lancer's Avatar
Interesting.... I have the MR DV, but I had thought about going with the forge BOV. I think I should be for with the MR DV until I upgrade more.
Old Feb 7, 2005 | 07:55 AM
93civEJ1's Avatar
yup, and this would also be the same as to why people get decent results running the single spring mod on the Type S.
Old Feb 7, 2005 | 08:17 AM
RallyRedEVO's Avatar
Stock BOV, 317 WHP on DynoDynamics, no surge, no boost problems = No need to change
