Which map for just cams no gears?
Old Feb 24, 2005 | 12:29 PM
hkfeet's Avatar
Can I use the stage 1 with hks camshafts without cam gears? If not, which map should I use.
Old Feb 24, 2005 | 08:17 PM
Dustin@Vishnu's Avatar
Try the 1+ map, but you might need to pull a little timing, or boost from the top end.
make sure you LISTEN FOR KNOCK if you try this.
Old Feb 25, 2005 | 03:09 AM
hkfeet's Avatar
Thanks
