Installed XEDE yesterday, car backfires and stalls...
Old Mar 8, 2005 | 07:30 PM
shiv@vishnu's Avatar
Originally Posted by namahs
get an aem, that will solve the problem.
and introduce a few others
Old Mar 8, 2005 | 07:44 PM
gsujeff55's Avatar
uh, yeah, lets spend 2500 on a AEM when we can fix the CLOSED LOOP problem by getting rid of the air filter that isn't really helping anyway.
hey, if you need a k&n drop in filter, im selling mine, has 2k miles on it, will sell it for $40 bucks.
Old Mar 8, 2005 | 08:16 PM
madpacket's Avatar
Hey, guess I was stupid enough to by the AEM short ram intake. What problems is it supposed to cause? Is any aftermarket intake worth buying?
Old Mar 8, 2005 | 08:19 PM
by aem, i assumed namahs was referring to an aem stand-alone ECU, not an intake
Shiv
Old Mar 8, 2005 | 08:51 PM
GTKage's Avatar
right
Old Mar 9, 2005 | 12:28 PM
S54M3's Avatar
Originally Posted by GTKage
right
Old Mar 9, 2005 | 04:10 PM
m2's Avatar
m2
boost...
Spoke with Andrew and verified that wiring was okay. Everything is wired up correctly so that's not the problem. The XEDE light also stays green while car is running as well as while I'm driving.
What amount of boost should I be peaking at with the XEDE mapped for my mods? It seems like others with same mods are running higher than my 21psi peak. Any thoughts?
Old Mar 9, 2005 | 04:25 PM
m2's Avatar
m2
I have had AEM on other cars with great results but what is different about the AEM EVO intake that makes it exempt from the stall issues that affect other intake system?
Old Mar 9, 2005 | 04:34 PM
EVO MR's Avatar
the mass air flow sensor
Old Mar 9, 2005 | 04:36 PM
gsujeff55's Avatar
the AEM needs constant attention and tinkering...weather change = tune change.
and have you tried putting your stock air box in to fix your problem? because i guarentee you it will and not lose any power in the process.
Old Mar 9, 2005 | 08:42 PM
m2's Avatar
m2
The AEM does not use the MAF sensor?
