Boost Controller and Xede?
hey guys,
i need some help with a decision i'm facing. i'm looking at buying the hks evc v boost controller. i was also looking at getting the xede soon after that. now what i'm a little confused is, do i need to use the boost control on the xede or can i use the ebc instead? the reason i want to use the ebc is because i can change boost on the fly and not need to hook up a laptop. will this screw up the downloadable maps? thanks.
You do not have to use the boost control function on the XEDE. I know of a few people using MBC's in conjunction with their XEDEs (same concept), I being one of them. Been running 22psi for almost 6 months now with no problems what so ever.
When installing the XEDE, just leave out the XEDE boost control wire and you should be fine.
well, I don't know if it's completely true. When I had my hallman MBC on my car. I had my Xede installed and tuned and I couldn't even run stock boost. I was hitting fuel cut around 18-19psi. and had to have my car tuned at 17psi. I remove my MBC and installed the factory BCS and my boost instantly went back up to stock 19psi and I've never hit fuel cut since. I figured there could have been a few factors that could have been the issue, but they all directly related to the MBC. I'm guessing that an EBC could cause the same problem, because they operate similarly... I'm obviously not a professional at this, but I figured I would explain my situation.
- Why do you want to be able to change boost on the fly?
-Chad-
-Chad-
Originally Posted by KLancer1997
You do not have to use the boost control function on the XEDE. I know of a few people using MBC's in conjunction with their XEDEs, I being one of them. When installing the XEDE, just leave out the XEDE boost control wire and you should be fine.
-Chad-
Originally Posted by boostfed
yeah, I think that was one of my problems. the boost controll wire was hooked up, because I plan on letting the Xede controll boost once I got my OEM BCS hooked back up. that could have been one of the problems causing the premature boost cut problem.
-Chad-
-Chad-
Funny thing is, I actually have my XEDE boost wire hooked up cause I plan on doing the same this April.
-chad-
Originally Posted by Jorge T
Did you leave the OEM BCS electrical connection plugged in? If not that may be the problem.
yeah, you have to leave it pluged in. or I had to anyways or it would throw a CEL...
-chad-
the other reason is really just because i want to.
Just wanted to throw this at everyone, I have an Xede which left me with great results however under a load when I went to full throttle I would hit the fuel cut point and then get an engine over boost CEL, the car drove fine as long as I didn't go full throttle. I just installed an Apexi AVC-R to try to correct the problem. I am still in the tuning stage but I have not gotten any of the afore mentioned problems plus I now have a boost guage to confirm what is going on. I havn't set it up to stock levels yet but I am just being carefull, don't want to break anything. End all, so far I like having both, the Xede and an EBC
