idle question
Old Mar 22, 2005 | 06:23 PM
BOOSTIN24's Avatar
idle question
Have a 03 evo with stage 1+. im idling at 850 but every now and then it dips to low into the idle and the car dies. should i raise the idle more. if so what and how. i was told that after camshafts and cam gears you should raise the idle a little bit.
Old Mar 22, 2005 | 06:44 PM
sylvester31's Avatar
ther's is a small screw right in that small bump where the arrow is on the picture, it'r right above the throttle body, that's where you can adjust the idle.
good luck.
Old Mar 22, 2005 | 06:49 PM
BOOSTIN24's Avatar
yea but how high should i raise it. i heard around 950-1000 should be where i should raise it to.
Old Mar 22, 2005 | 08:24 PM
i have mine at 1150/1200 and i have cams and cam gears. works fine.
Old Mar 22, 2005 | 10:03 PM
f125gpracr's Avatar
Wow..that high. What cams are you running?
Old Mar 22, 2005 | 10:57 PM
264/272 and cam gears set at -3/-3
Old Mar 23, 2005 | 01:28 AM
evo_dadi's Avatar
so how do you adjust it?
Old Mar 23, 2005 | 02:08 AM
leif's Avatar
yeah that is pretty high, once my engine warms up im at like 900 and i have cams n gears..
