Xede boost wire male connector problem
Hey Guys I have a problem I purchased a used Xede and the previous owner cut the boost wire so now I don't have the male connector on the boost wire if anybody knows where too buy a male connector for the boost wire please let me know thanks .
I was too lazy and clumsy to mess with swapping the boost wire into the ECU harness plug so I bought a harness extension from Z-1 and spliced the Xede boost wires into it and then just plugged it in between the ECU and the stock harness. A side benefit is that returning to stock is just a unplug away...
Go to any Harley-Davidson dealership and ask for either PN 73191-96: Contact socket or PN 73190-96: Terminal pin, depending on which side you need. MSRP for either one is less than a buck.
IIRC Radio Shack typically carries them also.
